Search the Community
Showing results for tags 'micro switch'.
  • Search By Tags
    • micro switch ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. I have a 2001 TT. Sometimes when I am driving the drivers side window will go down 10mm like I was opening the door, the interior light comes on, and then in a bit the window goes back up. This can happen 10 times in 5 minutes or not at all for days. I suspect a micro switch in the door but I am n...
  2. Greetings Renntechers. My 2002 C4 Cabrio top more often than not, will fail to open or close when using the switch. It always works (up/down) when I operate it with the key. Condition under which the top will consistently work: * insert key into the door lock * turn left or right and hold...
  3. Recently I developed a glovebox light issue on my boxster 987 s I Attempted to replace glove box light with led and now it doesn't work at all, even with the standard bulb is put back that worked before, nothing. Attempted to swap with the footwell bulb and light housing, nothing Following this...
