Search the Community
Showing results for tags 'hybrid system fault'.
  • Search By Tags
    • hybrid system fault ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. Hi All, I recently purchase 2012 Porsche Panamera S Hybrid and I have a hybrid Fault code P055600 Implausible Signal. My garage did a Smoke test and replaced the brake sensor and brake distance sensor. The conditions are: - “Fault Hybrid System” yellow warning pops up. - Hybrid system itse...
  2. Hello! My 2013 hybrid will not start after using my scanner to clear a check engine light. I had a check engine light/yellow Hybrid fault system so I replaced a relay since I had this problem before and replacing the relay cleared this problem for me. The check engine light was still on after replac...
