Search the Community
Showing results for tags 'fuel tank'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 3 results
  1. If I run the car at less than 1/4 tank full it's very smooth great acceleration and responsiveness. With engine running I went and filled up with 99 octane as usual and straightaway the engine stutter comes back!!!!!!!! Fyi it is NOT fuel quality. I've started a new thread for this but it's an old problem mentioned in previous posts and unresolved. Basically the ctt 06 with 114,000km has been hesitating and stuttering for a while when accelerating particularly under boost in lower gears through the rev range of 2k 3k 4k ish rpm, it also will vibrate and stutter revving the same rpm in neutral/park when stationary. (which is very weird). So after a lot of finding issues which helped the car overall none of them sorted this stutter out. Quick list, New oem Coils, plugs, n75 valve, air filters, purge valve, and Dv's, Fixed a lot of vac and pcv pipes which leaked Smoke tested intake no leaks boost is +0.8 Head Gaskets done a few 1,000 km all new parts gasket Seals etc. (problem was present before and after head Gasket work). I had a suspicion that the lower fuel level was playing a part in this but I can't work out why a fuller tank would cause running issues?
  2. A friend has a 2011 TT and claims his fuel gauge is not reading properly. We have taken both covers off and can move the floats around it seems to respond normally.This is the newer design that only has one fuel pump on the passenger side. I would think that the fuel level goes down equally on both sides (shared upper region) and then when it gets to the separation/split point, should the fuel level go down equally on each side or should the drivers side go down first and then the passenger side? He thinks they should go down equally but I am leaning towards not because the only device in the drivers side is the jet/suction pump and I think its sole purpose is to get fuel from the left side and push it into the right side pump area. That is how an airplane works so I could be totally wrong! Anybody know for sure how it is supposed to work? Right now, the drivers side is empty and the passenger side had 1/2 or so. Is the jet pump from the right side supposed to push fuel over to keep it balanced all the way down or is it supposed to drain one side down first?
  3. I took my Cayenne S 2005 to a dealer and he said the tank line to the canister line is broken. He said is not possible to fix it and I need to replace the whole tank. I took the car to another mechanic and he showed me the line broken. Any body can help me? Do I need to replace the whole tank? Do you think is possible to fix the line? This is not a case of recall? the part # is 95520107515 I have attached a picture.... Leo
