Search the Community
Showing results for tags 'fuel pump'.
  • Search By Tags
    • fuel pump ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 10 results
  1. 2005 C2S 997.1 I just changed my fuel injectors and want to check for fuel leaks before starting the engine. Does the fuel pump activate with the key in the key on position? If so, does the pump stay on in that key on position, or does it time out if the engine doesn't start?...
  2. Looking for suggestions. I replaced both fuel pumps of my 2005 Cayenne Turbo after the main pump died. Got it all connected back up and she runs great.... until it gets down to a bit under a quarter tank. Sometimes the engine just quits, other times the throttle gets intermittently rough, it shudder...
  3. Hi what causes fuel pump fuse to keep blowing FS 13 it is for right side fuel pump, I changed the fuse but its blowing again.
  4. Hi there, my cayenne won't drive as long i have the relay placed at 1/6 (the 404 relais) functioning. Once I take it out the car runs perfectly on one pump but once I put it back in the car stops working although I hear both fuel pumps working. What to do? Thanks for your response.
  5. First time post... hope to start contributing to the forum now! 09 GTS with 93k and excellent maintenance history, recently getting long cranking times and sometimes rough idle at startup. Starter is working properly so we can rule that out - not sure what to tackle first, coils? fuel pumps?...
  6. Hello Porsche experts, I recently purchased a used 911 Carerra, 2003 and had the fuel pump fail. So I looked around in Orange County to find a Porsche mechanic and ended up taking it to Hergesheimer. They replaced the fuel pump but a few days latter I experienced something very troubling. The car...
  7. My left fuel (primary) pump went out on my 2004 Cayenne S, when I went to order the parts from www.sonnenporscheoemparts.com they said Porsche updated the fuel pumps and I would have to replace both because the old fittings will not fit to the new pumps. Is anyone aware of this update, have they in...
  8. Hi Everyone, So recently had a fuel pump go out on my C4. Conveniently way far from home. Got a local shop to repair, and they put the fuel pump in from the C2. The car runs, but doesn't feel quite right. Does anyone know the difference between the two pumps, apart from the part number of course? W...
  9. Hello !! I have a mystery I need help with. My car is a 2001 996 Turbo manual. I drove my car for 30 minutes, parked it and went on an appointment. Returned an hour later and...it would not start and ended up with a tow truck recovery. Well, having followed all the good advise on reasons and cures...
  10. 2004 Cayenne Turbo Guys, I could use some advice. Cayenne has begun to leak fuel from the driver's side somewhere near the top of the tank. I can see small amounts of fuel running down the seams in the tank and you can smell fuel outside the car, but not inside. I can sometimes see a few drops...
