Search the Community
Showing results for tags 'exhaust upgrade'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. Hi all, This will be my first post, thanks for a great forum ! I've recently purchased a exhaust system from Design911 in the UK which has the valvetronic function on. This is said to replicate the PSE which my car does not have factory installed. Wired it up and put the vacuum hoses, tested the system and it works fine. Over to the issue for my car: When starting up the car, the neutral positon of the valves is open, which means a lot of noice from the exhaust. When switching this by the solenoid, sending vacuum into the system and the valves closes. This means less sound. But when the valves is closed the car wont run properly at the RPM range of 5500-7000 RPM's there is also fault codes for misfire on cylinder 2. The strange thing is that this works perfectly when the valves is open. I've tried two differnet vacuum sources, into the ressonator and also for the left hand side cooling system vacuum solenoids. Without any differnce. I tried to run vacuum directly to the vacuum actuators on the exhaust without any difference and also tried manually applying vacuum and using a one way check valve to keep the vacuum while not connected to the cars vacuum line. No vacuum leaks, no fault codes when driving with the valves open. Same result every time. So have anyone had some similar issues to their car ? Thanks in advance for any help !
  2. Will installing 200 cell cats on 997.1 cause a CEL? If so, is there anything that can be done to eliminate it? Also curious whether their use on car with PSE will significantly increase exhaust loudness as I'm not really looking for more sound. Appreciate any feedback including performance experience when combined with competition throttle body and intake plenum. Thank you.
