Search the Community
Showing results for tags 'clutch switch'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Please help, After thoroughly searching for someone who has had this issue, I am still lost. Vehicle is a 2000 Boxster 2.7, 5 speed manual. Vehicle has factory Becker radio with tape deck. CDR 220 I believe. I have replaced the ignition switch as recommended for similar problems, but there were no changes First, the vehicle will sometimes not crank when turned to the starter position. It takes multiple turns and sometimes even locking and unlocking the vehicle before it will start (acts like clutch is not depressed when trying to start). It seems to be happening more often and I am afraid it may not work at all in the near future. It is not the battery. Electrical connections to battery are good. I thought possibly the clutch switch but it does not seem to have any effect on it from what I can tell. All fuses look good. Radio fuse in footwell fuse box was blown but I replaced it. Secondly, the Radio does not turn off or on when key is turn to ON position. This happens 100% of the time. The radio can be turned on with the On button in the same way that it can be with no key in the switch. It has to be manually turned off or else it will play continuously. Even if the vehicle is locked. The red LED flashes when the unit is off and the vehicle is running. More pertinent information, All of this started happening after I removed the factory head unit temporarily. I have read different things online as what to do with the brown/blue wire that senses the radio in the dash. Some people say ground it out, others say to tape it off (no ground?). I cannot tell if it makes it act differently if it is grounded, but I may not be getting a good ground (short wire in dash)... Wire cannot be reconnected as originally was. Horn honks once after locking (I figure this is because of the radio security wire) and dash led blinks twice in rapid succession continuously. What should I do with this wire? Why would this affect the ON and OFF of the radio when the ignition switch is turned? Is this linked to the starting issue? I think it may have done the starting problems a couple times before removing the head unit, but I am not positive. It has definitely gotten substantially worse since about the exact same time though. I have already replaced the ignition switch. Also, can I disable the clutch switch entirely or will that not allow the cruise control system to function? Please help!!! Thank you all. The boxster community is amazing!
