Search the Community
Showing results for tags 'climate control'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 4 results
  1. I recently became an owner of my very first Porsche (2000 Boxster S). For the most part it's in a great condition, I got it off coparts and wasn't sure what to expect, but very mechanically sound. I have been experiencing some minor issues across the board and looking for any information to help me. Starting off with the easy stuff, there's a crack in the coolant reservoir, I've already bought a replacement, missing driver side mirror, and passenger brake light is out. The issues that I still haven't figured out, the biggest one being a potentially bad cluster, all fuses and relays seem in good condition. On my cluster I have no odometer/speedometer/tachometer, I do have fuel and coolant levels. I've deduced the cluster itself is bad and bought a replacement. I intend to pull the programming from the current one and reprogram the new one. My biggest question here is which eprom device do I need to be able to do that? Assuming that cluster replacement fixes that issue, my next issue is a potentially dead climate control unit. I have no power/ electronics going to the unit, and the fans/blowers do not work. So open to any and all suggestions on that issue. Lastly my spoiler is stuck retracted, again all fuses and relays seem to be in good condition, which leads me to believe this is just the spoiler motor. I would appreciate any advice or suggestions or anything to help get this beautiful Porsche back to 100%. Thanks Everyone!
  2. My 2004 CS seems to be a little weak to get up & go since I got it last summer, but still much more power than the car it replaced. I wrote it off thinking, "it's not a turbo, so what do you expect?" I did the plugs and air filters in the fall, and replaced the valve cover gasket on the driver side where it leaked the most. Still no major differences, not that I expected any. Went out to buy some throttle body cleaner the other day, and on my way to the store I got a phone call which prompted me to turn off the climate control (click the fan speed down to 0, temperature display shows 'OFF'). On my drive home the Cayenne drove *totally* differently. Really ballsy on the pickup, tons of pull. A few days later, I realized the car was especially chilly / foggy, so I turned the climate control back on. Sure enough, she was sluggish again to get going! Anyone see this kind of thing before, and know what might be causing it? As far as I know, most cars "back off" on A/C and heat when the driver calls for acceleration, but that's definitely not happening here. Also, with the colder weather I'm not sure whether the Cayenne is engaging the A/C in addition to the heat. Any insight would be appreciated!
  3. 2002 Porsche Boxster S, 6 speed, having a strange problem where the heat only comes out if I put it on hi, then it gets hot as all hell, have to turn the fan down. If I click the down button the first temperature it sets it too is 85. Then its cold. If I lower the temp it gets colder and colder, AC works gets icy cold putting the temp the other way. But no warm air, only hot air, and only when set to HI. Any thoughts on what to look at? Thanks!
  4. Hi everyone. I have a 1998 996 C2 manual RHD. About six months ago the heater/climate control fan started messing about. Mostly it would work, but now and again it refused. This became: usually worked at first start-up but thereafter usually refused, but might spark up at some point during a journey. (it seemed to me that opening a window[because I was fogging up] kick started the fan, but that may be coincidence) The little fan under the passenger air vent was a little noisy and sometimes the heater fan would click a bit like a bicycle wheel with a playing card pegged to it. I changed the ignition switch (read about intermittent electrical maladies being linked to it). No difference. I bought as new (S/H) heater fan and when I took mine out found that the connectors weren't compatible so I had a good look around and put mine back in (I read that when fans stop they stop, they don't work sometimes and others not). I then replaced the little fan under the passenger air vent. Again no difference. Rather than be intermittent the heater fan has stopped all together now. So I have just replaced the heater/climate control panel unit (klimabetaetigung) with one that has exactly the same numbers as mine. It seems to work fine - I can hear lots of things happening when I change vents, switch aircon on and off etc. But still the heater fan won't do what it should. I'm at a loss to think of what else I can replace - I suppose the heater fan could have finally given up the ghost after a slow painful death, so I can replace that. The only other thing that seems wierd is that when I changed the little fan under the passenger air vent the climate control (when it worked) seemed to think the car was around 5 degrees hotter than it really was - put it on max and warm air comes out, but turn it down below 27 degrees (when you know the cab's no hotter than 21) and cool air comes out. I have no trouble with coolant or air con, all checked and serviced by Porsche. Help please.
