Search the Community
Showing results for tags 'cardan shaft'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. Just realized...The title is wrong. It should say CARDAN SHAFT INSTALLED VERTEX ESP 2 PIECE SUPPORT. Don't know how or why I put in "used" nothing is used... Hey All, Well my struggles continue. My Cardan shaft bearing failed for the second time on my '04 Cayenne S. The original was replaced around 60K+ and this one failed at 135. Since it wasn't covered under warranty I opted for the Vertex 2 piece Clamp on solution. Once the bearing ring is cut and removed, I used a razor blade and cut off the rubber. With a really good razor blade and mechanics gloves I was surprised how cleanly I was able to get off all of the rubber. Don't get me wrong it took a lot patience and time but it came out really clean. I then pride off the two sealant bearing rings and carefully repacked the bearings. The bearing ring spun smoothly but after watching the Vertex video I decided what the heck I will pack them. You would be surprised how much new grease I was able to pack in there. Pressed the rings back in and started clamping the Vertex Supports in. There is one thing that really pissed me off about the Vertex EPS solution. They did not provide a long allen wrench. I mean really, for $480 throw in an extended length allen wrench. I had to struggle with a normal size one as I didn't have the correct extended one. Now onto the rubber flex disc. I called vertex and they said if your current one is in good condition you don't need to replace it. Put the supports on, drive and if a vibration is present then put on the flex disc. Well, I just came in for another beer before I button everything up but I think I am going to put on the flex disc while I have the main support bracket off. I will let you know how that goes in a bit.
  2. Hi Guys, I am a new member. I have been stumped trying locate a vibrating noise (that lasts approx 2-3 seconds) that my Carrerra 4 makes under load @1500-2000 rpm that's driving me nuts! As soon as the rpms get above 2000 rpm it goes away. The best I can describe the noise as the noise you would hear if the was a loose shroud with something, like a driveshaft rubbing against it. I can't produce the noise while standing still, I have to be moving. At first, I thought it was the exhaust, I have since eliminated it as the culprit. The noise comes from under the car (can't tell if its front or back) . I have checked the spark plug covers and the heat shields as well. CVs are good and so are the wheel bearings. I have looked at every post regarding "noises" on this and every other forum on the net and my best guess is the flex/guibo connecting the cardan shaft. However, I can't find in any of the posts how to go about inspecting the Guibos on the car. Could somebody help me shed some light please? I recently changed the transmission mount, engine mounts, new IMS and new RMS. Thanks in advance for any help.
