Search the Community
Showing results for tags 'camshaft timing'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. Here is a Camshaft Deviation situation with a much tighter focus than normal.I have also included the best links I found to help others who find this through Search.This is a 5 chain engine.2001.Boxster S. The engine is just rebuilt by me. It runs wonderfully well with no Fault Codes, none. Great oil pressure.compression even on all cylinders. New chains,but original tensioners,new wear pads,new IMSB, IMS shaft pinned. But Bank 1 Deviation is negative 8 degrees. Bank 2 is much less than 1 degree negative. Spec is max 6 degrees +/-. Deviation is rock solid on both Banks throughout the rev. range(except for normal Variocam change). No Pending or Active Codes. I recently had Bank 1 Cam Cover and Cams off to rectify an obscure VarioCam issue (Thank you PorscheTech3!). I re-timed the Cam on Bank 1 using the Baum Tools. The tools are excellent but clearly(?) need a degree of finesse in use that I was unaware of. 8 degrees CRK per Durametric is only 4 degrees at the cam so it is impossible to do a visual check of the slots in the Camshafts to confirm if this is a static cam timing issue or a Camshaft system component failure. So I am resigned to re-do the timing but need reassurance on the precise technique to use before I R&R the Cam Cover again. Cam Timing Details are in the links at the end of this Post. Here is the tentative plan that I hope others will be able to correct : Follow Procedure in links below to lock the Cam with the Baum Tools close to TDC. To get perfect Cam timing, I'll need to very slowly rotate the Crankshaft forward toward TDC. Only when the tools fit perfectly will I lock the Baum Cam Timing tool. Then I'll try to insert the TDC Crankshaft Locking Pin. Knowing that Bank 1 is excessively retarded 4 degrees(cam), I should expect that the Crankshaft Locking Pin will not slide in easily when the Cams are perfectly timed. At this stage I should loosen all the Camshaft Sprocket bolts. But not remove the (old) Chain Tensioner - right ? Then the Crankshaft should need rotating 'forward' 8 degrees until the Crankshaft Locking Pin slides in easily.Then tighten the Camshaft Sprocket bolts. Then rotate many times and re-check. The Bank 1 Timing Chain Tensioner is still very powerful and seems as 'strong' as Bank 2. When I refitted Bank 1 Tensioner last time, it required serious muscle to force it upward while delicately engaging the threads. So I assume it is functioning adequately and is not the cause of the out-of-range Camshaft Deviation .I am assuming it is original(90,000 miles). What other components should be checked ? I did check the Camshaft Position Sensor for correct fitment and the Reluctor ring for damage during the VarioCam repair. https://rennlist.com/forums/996-forum/594122-how-to-set-cam-timing-on-996-a.html see Post #7 http://www.pelicanparts.com/techarticles/Boxster_Tech/16-ENGINE-Camshaft_Swap_and_Chain_Tensioner/Gp1800.pdf Good dwg and description of mechanism and parts. Please add your best links if you have any in your replies so that this may help others with the Deviation issue? And thanks in advance for any suggestions and corrections.
  2. Hello all, This is a continuing repair to what started as a camshaft deviation out of spec leading to the replacement of the chain tensioner pads / brake pads / chain ramps on my 2000 911 - 996 5-Chain engine. Seen here: That odyssey has since been resolved but I now have a new issue. Quick background: Removed camshafts, readjusted the camshaft chain timing "marker" positions, replaced tensioner pads, reassembled everything per factory specs. On first start up got very rough idle and bad misfires. At first I thought it may have been my timing was off but went back and visually inspected all and all looked correct (visually). Upon further inspection realized parts guy had given me Bosch 7403 plugs instead of Bosch 7413 (2000 Porsche 911). Current issue: Switched out and installed the correct spark plugs and no more continuous misfires / backfires. Did the initial reset (wait 1 min with ignition on / turn ignition off / wait 10 sec) On the first start up it did misfired / back fired once but I assumed that was left over fuel. Car now runs but very rough and threw 2 codes: - P0300 : Porsche Fault code 62 - Misfire damaging cat. converter - P0301 : Porsche fault code Cylinder 1 misfire damaging to cat. converter Also, took these readings: Actual angle for camshaft bank 1: -12.53 Actual angle for camshaft bank 2: 3.05 On positive note the main reason for doing all this work was the original problem / issue of tensioner / brake pad wear which was giving me a -10 / -2.92 reading is now: Camshaft position 1 deviation: 0.00 Camshaft position 2 deviation: 0.00 So the question is now are the Actual angle for camshaft readings within specs and could incorrect timing be attributed to these new issues? And... Do I have to give the DME time to "relearn"? Txs all
