Search the Community
Showing results for tags 'camshaft soleniod'.
  • Search By Tags
    • camshaft soleniod ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. A creature has chewed threw the wires that come out of the camshaft solenoid 1-3. Is it possible to remove the solenoid by removing the 2, 10mm screws and will the solenoid slide out? Is it possible to repair the wires once the solenoid is removed. All that's left is a 1/8 of an inch of wire to wor...
