Search the Community
Showing results for tags 'cam timing'.
  • Search By Tags
    • cam timing ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. I need some advice on what further tests to do before I start disassembling the camshaft. The code is "1341 = Camshaft adjustment Bank 1 below limit value." But I think this is misleading. Normally , this would be just a failed Solenoid or Variocam actuator. Btw ,these comments apply equally t...
