Search the Community
Showing results for tags 'broken studwater pump'.
  • Search By Tags
    • broken studwater pump ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. - 2001, 2.7L Boxster, 5-speed, 94k mi. I broke one of the studs while replacing the water pump. The good news is, it's the stud that has the easiest access from the interior of the car, with the access panel removed. The bad news is, I can tell the stud probably broke flush along the block. I ha...
