Search the Community
Showing results for tags 'blown engine'.
  • Search By Tags
    • blown engine ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. Hey guys, I have 2000 Boxster S thats been sitting for months now because it has a rod bearing issue. I found a running 2.5 for cheap becuase its a family friend. I wanted to know what would be needed to do a swap like that? Would it be harder or simple. Im thinking the DME would need to be remapped...
  2. Had my 2004 996 C2 towed to the shop after I heard a noise from the engine and it quickly stopped running. The diagnosis from my mechanic is a blown engine. There is lots of metal in the oil but apparently it is not the dreaded IMS failure (had IMS upgrade by LN Engineering installed 2 years ago). T...
  3. I think I all ready know the answer to this, but here goes. I just picked up my car from the body shop last night, so now you know I recently wrecked my 02 Boxster, but dialing my phone while driving to set up an oil change then running into the car in front of me still is not the dumbest thing I'v...
