Search the Community
Showing results for tags 'blleder valve'.
  • Search By Tags
    • blleder valve ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. I plan on using the Motive to bleed my brakes this weekend and after searching the forum and maintenance manuals I cannot find an exact value to torque the bleeder valve. I have seen reference to 7.5 lbs-ft and 9 lbs-ft. I assume this is an ok range (staying on the low side, assuimng no leaks). I...
