Search the Community
Showing results for tags 'battery light'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. I had the alternator changed 2 years ago on 2001 Boxster, with OEM replacement. I noticed cruise control would come one when first started but if not set, it would go off and you could not get it to come back on unless you shut off the car and restart it. I also noticed that the panel lights would flicker at times, like a candle flame. The alternator light would flash on for several seconds intermittently even while traveling at 80 MPH. A few weeks ago, the battery light came on and stayed on. I let the engine cool and restart but same issue. I started and rev'd the engine up to 6000 and snapped my foot off the gas. The light went out and it started to charge. Last week, I was coming home from the airport and the ABS light started to flash, then the air bag warning started to flash. BUT THERE WAS NO BATTERY LIGHT ON. I pulled over and shut it off. It would not restart - the battery was down to 10.6 volts. It was not charging and there was no warning The warning light operated normally. It came on when you turned the key and went off when the engine started, but there was no charging voltage. Local European cars specialist told me the battery had a shorted cell. He replaced the battery and assured me everything was okay. I drove the car for a day, then noticed that starting was sluggish. I measured and there was no charging and no warning lights. I took it back and they tested the alternator on a Snap On tester. They said it was perfect. They consulted with Porsche dealer who said it was impossible for the alternator not to charge and not have a warning light. I insisted that they change the alternator. Everything was solved. the flickering lights, the cruse control, the charging, the intermittent battery light flickering. All solved. Still no rational explanation as to why the battery light did not come one with no charging taking place. Measurement - wise. when it was acting up, 13.5VDC stable, but sometimes very rapidly (Fluke digital meter could not track fast enough) varying between 13.5 and 14.5, and that was causing the dash lights to flicker. When the battery was going dead with no battery light on, absolutely no charging voltage.
  2. 2004 CS 84K. Bought the car 6 weeks ago. On thanksgiving day, prior to a long trip, the Battery light came on at start up and then went off. Each time I start the car, I have to bump the key twice to start. Battery light goes off and all is good. Volt gauge reads 14ish volts while running. Interior lights seem to cut off (when car isn't running) way too soon, and the blower motor is making weird noises and sometimes takes a minute or so after start up to begin working. Is it the battery, and if so which one? Under the seat or in the trunk?
