Search the Community
Showing results for tags 'battery draining'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Okay this is more than likely my fault for not getting my bulkhead drain grommets sorted out properly last autumn (they were blocked and causing water seepage into the cabin but when I was trying to clean it out I managed to push the old n/s grommet into never-never land.l bought a replacement and then did the same again! (To be fair it is a ba***rd to access as you'll know if you're familiar with this). I intended to try and access the never-never land area by removing the inner wheelarch liner in the Spring - by the way, as a separate issue, does anybody know if that will allow me to access/ retrieve/ refit the damned grommet? Anyway, onto the current issue.......the passenger carpet got wetter than I realised and although the ECU/ alarm unit seems positioned high enough away from the floor under the seat and is not covered with the carpet, I'm guessing that this has caused the problem that I have now. I.E. The central locking won't work now and only the drivers door can be locked with the key, plus the battery drains completely overnight. I took out both the passenger seat and the carpet to have a look, but although there was some water (not that much as there is a small hole drilled in one corner acting as a drain!), the ECU/ alarm unit appeared to be dry. Having tried to find a solution on various forums/ searches, I haven't seen this fault replcated or explained anywhere else, although my thinking is that it is actually the ECU which is the problem due to moisture ingress? Anyone know if I'm right and if it is the ECU, what's the best solution please, repair (how?) or replace? I've read some stuff about a reprogramming issue with new units? Any help much appreciated. Cheers, Tony
