Search the Community
Showing results for tags 'atf leak'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. 1999 Carrera Tiptronic oil pan leak and fix About six months ago I noticed the transmission pan was wet with ATF. Wrongly assuming the gasket was leaking, I changed the gasket and filler round seal and while I had the sump off changed the filter too. Torqued everything to spec and filled her up. Everything running smoothly. Three months later the transmission started to slip. Had a look underneath and the pan was wet again. Cleaned it up so it was totally dry. Took the car for a short run and left it overnight. Next day the pan was dry around the sides but wet between the drain plug and filler hole. Wanting to isolate the leak I dried the pan again and taped blotting paper around the drain plug and another around the filler hole. Took the car for a short run and left it overnight. Next day the drain plug paper was dry and the filler hole paper was wet but touching the inside of the filler hole I could not detect any fluid. To pinpoint the leak I cut a 50mm hole (size of filler hole) in the blotting paper and taped it around the filler hole. I then stuffed paper into the filler hole and taped that up making sure that the two pieces were not touching. Took the car for a short run and left it overnight. Next day the paper around the hole was wet and the paper in the hole was dry. Finally, I knew where the leak was coming from. Not wanting to spend over AU$1,000 on a new oil pan, I ran some JB Weld over the join between the filler hole and pan. (See photo) It has been 3 months since the fix and the pan is still dry. I have also applied 80 Nm of torque to open and close the filler hole plug and this has not cracked the JB Weld seal. I hope this info will help anyone with a similar leak. 1999 Carrera Tiptronic oil pan leak and fix.pdf
