Search the Community
Showing results for tags 'ac compressor'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 3 results
  1. Yes I'm back with another problem. Ctt 06 with 4 zone climate control, 45 degrees in dubai and the AC starts to blow hot. Had new gas 1050 grams as per spec after the head gaskets were done 4 months ago, vac test showed no leaks then. I had to keep turning it off and on to get it to kick back in which is suspiciously like the compressor clutch not kicking in. So questions: Possibilities of the cause of intermitted fault? Can compressor be repaired if removed? Will be swapping the relay later from the rear defogger (same part number 40a relay) to make sure it not that and yes a trip to the local shop for gas volume check and leak test. Ruling out the control flaps as when I increase temp to 29 it is blowing super hot and all the control flaps and noises can be heard switching, and back to low setting gives hot air but much less roasting.
  2. Hello, I made a short video that shows how to remove the third A/C compressor bolt from 996 Carrera 2004. You do not want to strip this bolt. The key for me was to use a borescope which gives you the confidence to turn the bolt as you know for a sure when your grip is good enough. I'd recommend you to buy two USB borescopes, they are cheap. One small one with auto focus and one good quality microscope with manual focus. I am using the latter here. For the better quality one I recommend Andonstar 2MP endoscope. Search ebay with keywords: andonstar 2mp usb endoscope . Should cost $70. Video here: Note that my focus for this video is not that great, I only care about getting a solid grip.
  3. I have a 2004 996 carrera with an aircon problem. Basically the air coming out of the vents is cool but not cold. I thought this was down to the system needing re gassing so I had this done. The performance seemed to improve for a short time but is now under performing again. Also the AC compressor clutch seems to be engaging/disengaging every 15-20 seconds on tickover. Has anyone had a similar experience or can shed any light on this matter. Cheers Mike.
