Search the Community
Showing results for tags 'abs psm errors'.
  • Search By Tags
    • abs psm errors ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. 14 Cayenne Turbo S has numerous system failures. PSM codes won’t clear. Right front ABS wheel speed sensor fail message and replaced all four with new sensors still won’t clear. Replaced all plugs, coil packs and the MAP sensor as well as battery (coded battery properly). Thinking it may be wiring h...
  2. My dealer quoted me $3000 to replace Broken ABS module, I am getting constant PSM and ABS workshop messages, dealer stated ABS module corroded with liquid from cup holder. Is the repair cost reasonable ? Is it simple replacement which a handyman can perform ? Any help will be appreciated. Thank...
