Y2K996C2
Everything posted by Y2K996C2
  1. I am having difficulty finding a part (see attached). It is a part from the cabriolet rear wind deflector hinge. This part is responsible for holding the deflector up in the wind and allowing you to put the deflector back down again. Currently mine is moused in the upright position. If the pin for the hinge becomes loose, this part drops out. Unfortunately I have lost one. Unless you have both parts on either side, the deflector does not stay up in the wind. There doesn't seem to be a Porsche PN for this and all the parts sites will only sell the complete wind deflector which is expensive. Anybody have any ideas? Next step might be to buy a block of aluminum and make my own, a big job for little return.
  2. Is it true that Porsche offer every part for every 911 model or is this just hype?
  3. I just had my clutch, pressure plate, release bearing, flywheel, master/slave cylinder and RMS bearing replaced on my Canadian 2000 996 C2 CAB. Now my pedal engages at the top of the travel (worse than my old worn clutch). Is this an adjustment (like the old cable adjustment) on the hydraulics or will my indie have to drop trans again?
