mik3c
Everything posted by mik3c
  1. I have a 2003 996 C4S that makes the "blowing across a coke bottle" sound from the vent hole behind the gas cap door. It happens at idle after the car is warmed up. There are no other symptoms. Doing some research, the vent hole is connected to the EVAP system. I hooked up durametric- no faults found. When the fuel filler flap is activated, the howling noise/ vacuum from the vent hole goes away. Found this Pelican article, but not sure if the is the problem. Replacing Your 996 Fuel Line Vent Valve / Bleeder Valve - Porsche 911 Carrera & 986 Boxster - Porsche 996 Carrera (1998-2005) - Pelican Parts Technical Article WWW.PELICANPARTS.COM If you are having trouble filling up your car with gas, your check engine light keeps coming on, or you hear a howling sound you may have a faulty fuel line vent valve. Here is a video of the noise imgur.com IMGUR.COM Looking for tips to help diagnose and solve this issue.
