Docdanracy
    Auburn
    2003 BoxsterS
    1984 Carrera
    1970 914 1.7L
    1973 914 2.0L
    1987 Carrera
    1970 914-6 2.7L RS
    1987 951
    1999 Boxster
    1990 964
    1974 914 2.0L
    1975 914 2.0L
    1999 Carrera
    2000 BoxsterS
1,131 profile views
Docdanracy's Achievements
  1. You are correct Loren Second number is 140.01 I assume on wheels with both of the second set of numbers is the 10" variety I believe I had a set of those rear wheels on my '99 996.. Hollow spoke
  2. Found a very nice set of wheels.... Need to figure out if they are hollow spoke or solid and the sizes.. Seller really doesn't have an understanding of what I am looking for.. Here are the part numbers from the back of the wheels 99336213405 99336213800 also 9933621400A So what is the verdict? Thanks
  3. Try checking your spark plugs. A loose plug can cause a high pitched squeal...changes with RPMs I had a similar noise and found two loose plugs.
  4. Thanks for the quick reply My current Boxster is a 2003S I purchased a few months ago...it is the lowest optioned BoxsterS I have ever seen. Bose Stereo and Wind blocker....that's it. So obviously a little tinkering is in order. A 4 stalk is needed! I am getting a used stalk from a buddy who just completed building a spec Boxster. I will be getting all the wiring complete to the dash plugs too. I live in Auburn now. I met you years ago at a home in Almaden Valley... Henry was his name I believe....also met ToolPants there At that time I had a 1999 Box
  5. I know OBC can be initialized prior to installing a switch or stalk, with OAT being the default. Can the cruise control be initialized in the dash and DME prior to installing the 4 stalk? Loren, do you still live in Roseville area?
  6. Ok So on another set of wheels 8x18et50 10x18et 65 would those fit without spacers or would I need 12-13mm spacers for the rear? Thanks again
  7. Rears: 9x18 ET43 with 275x40x18 rubber Fronts: 8x18 ET57 with 245x40x18 rubber Will these be direct bolt on or will spacers be needed? What width spacers? Will the rear have any interference inside or outside? Thanks
