robbieracer
    Sacramento, CA
    2000 Porsche 911 (996)
robbieracer's Achievements
  1. I'm hoping for a dual row, but can't be 100% sure until the trans is dropped. I just drive it like I stole it and try not to think too much about it.
  2. Do you what your build date is? There's a sticker on the drivers door that specifies the date. I believe it's right upper corner if the door was turned 90 degrees. I knew someone with 3/00 with dual row bearing and mine is a 7/00 but not sure which one I have, will wait until I need to replace the clutch. Just curious, thanks!
  3. I also have 285/30/18 on the rear (Pirelli Rosso), no rubbing.
  4. Super Sports are 300 treadwear and don't come in 285/30/18, so not a viable replacement for the Rosso. You'd have to go to PS2 for a similar tire, but they cost about $100 more per tire than the Rosso.
  5. I just put 4 new Rosso's on my car a month ago. There are limited tires in a 285/30/18 with 200 - 220 treadwear. Since the rears go out twice as fast as the fronts, I may have a dilemma when I need to replace them if Pirelli Rosso discontinues that size.
  6. I'd take a 996 Turbo, I already owned a S/C'd E46 M3 (440 whp), nice car but moved on; style is very dated now...
  7. Great mod, did this while I was removing the A pillar to hardwire my radar detector. The range is very much improved. Thanks!
  8. Try 6454 That worked. Thanks!
  9. BE4462Y5042824, thanks! Just replaced the battery and the code I received from another website didn't work (6453).
