AussieJet
    Western Australia
    Porsche cayenne turbo 2005<br />Audi A1 sport 185
    Jaguar mkii<br />Daihatsu charade detomaso <br />Nissan 180sx sr20det<br />Toyota chaser vvti 1jzgte<br />Toyota landcruiser
AussieJet's Achievements
  1. HVAC blower fan. The carbon brushes wear out over time.
  2. How is the timing been centred is the question. These engines have 35 degrees of variation due to the variable actuator. The camshaft timing is set to + or - 6 degrees, the variable actuator then centres the cam for precision timing. Meaning your computer will always show your timing as perfect. Unless someone has messed up the timing it should be considered ok. It is the variable system that plays up. If the timing chain was to stretch enough to cause a CEL it would be noticed at startup or efficient cruise speeds when the variation is at its limit. It’s more likely to be an actuator or solenoid. Simply checking the camshaft timing to within the factory specs will not diagnose this fault. You would need to check the operation and travel of the variable timing actuator.
