Gator911
Contact Methods
  • Website URL
    http://
    Sarasota, Fl
    99 C2 Aero
  • Future cars
    Nothing yet!
    1995 BMW M3 Turbo (708hp)
Gator911's Achievements
  1. My belt tensioner seems to be toast. It isnt providing the necessary tension on the belt... When I replace the tensioner, What is the part # that I actually need. Im assuming that the roller and the arm are ok? Do i replace the hydraulic portion of it or is it all one piece? thanks!
  2. My trunk release lever is EXTREMELY hard to pull. I feel Im going to break something and it has a decent amount of slop. Any ideas? Its a difficult topic to search. Id like to fix it before I really break something.
  3. I just replaced my 4spoke with a 3spoke and I have the same problem... Did you find a solution? The wiring seems correct and it looks like it could only even go on one way. This is WEIRD!
  4. Great stuff! I will be doing this next weekend I think
  5. I am going to bump this up since Im sure someone int he past couple of years has more experience. I searched and it led me to this... Im having the same issue and want to DIY today but would like a preface... -Keith
  6. I figured it out...Pretty easy but I panicked!
  7. I just took out my parking brake and i didnt notice these 2 small pieces and untill they fell... Does anyone have a schematic or can tell me where these pieces go? They are a circular and a cylinder type piece. The only pieces other than the 2 nuts...They go on the rod from the brake lever somehow i think... -Keith
  8. It is not the problem. It acts as if the key forgot who the car was... I did an extensive search and it seems to be a fairly common problem...I am now looking for alternatives to 200-300 for a new key! I did not find anything about a switch though
  9. Is there a fuse for the keyless system? The key fob still lights up so Its not the battery. Its not a long red light or anything either... What can I do? Resetting does nothing... -Keith
  10. I know that the speedometer reads higher on the 02, but with that aside, will it work? Also, will the DME override the cluster to display the correct mileage?? please help!
  11. I have to pull the key out and then i put it right back in...
  12. I always leave the key in the ignition while in the garage...Maybe i should stop
  13. Sweet car! I wish i had LSD and clear headlights! -Keith
  14. Oh its not a temendous amount, less then a Qt....It just burns, and doesnt fall in one place. That is why i suggest a larger container to cover a bigger area... Look at it this way; it's enough fuel to fill that filter, and a tad extra from the lines...
