bmbratz
    uk
    Porsche cayenne s
  • Future cars
    turbo s
    bmw 530d
701 profile views
bmbratz's Achievements
  1. Hi Sorry not good news I had this issue and cost me £££'s I tried cheaper methods but only option is replace steering column I'm in the UK but have seen an Australian mechanic who have found a way of getting round this problem see video. Maybe someone can contact him and get his know how to us living in The UK etc.
  2. Hi Update had to order steering column from Porsche but my mechanic is having difficulty coding it to the car. Any tips what he could do?
  3. Hi Ok thanks my mechanic is having a look into it!
  4. Meanwhile just to update I had the car towed to my local mechanic the AA had to put the gearbox into emergency neutral manually to tow it away as everything was dead except for the air con and stereo . My mechanic tried to plug it into his machine but the car would not communicate he did mention he could only communicate to an ecu in the steering column but nothing else he is currently still trying to get the whole system to "wake up" he even tried emergency mode but to no avail, any input guys greatly appreciated.
  5. Sorry when I unlock the car on the dash it says steering faulty
  6. Hello hope you guys girls are well, I have a steering fault on my Porsche 2003 4.5s Cayenne now done 108000 miles rendering the car totally useless battery is ok wont turn over nothing. Is it bad news in terms of ££'s. I do like my car but it is getting on a bit now. I had the water pipe upgrade would prefer to keep it as cant afford to upgrade. Its has been converted to LPG 7 years ago and has been faultless with an electronic valve saver fitted .Thanks in advance.
  7. http://www.specialistvehiclepreparations.com/blog/porsche-cayenne-heater-flap-replacement
  8. Wow cracking piece of info wrinkledpants looks like a whole dash out jobbie then no short cuts
  9. Hi I'm gonna jump in this too as I've had no luck as my A/C flap actuator which defrosts the front windscreen does not direct air to the windscreen no more, when I press the windscreen defrost button I can hear the air going but is blocked and not going up toward the windscreen. I think it would be a good idea to start a thread on a solution to these A/C flap actuators.
  10. Hi, My license plate light measures 84mm in length the reverse cameras on ebay which state they are for cayenne/touareg are 77m in length can't find the right reverse camera to fit my 2003 cayenne on ebay.co.uk
  11. Hi Was hoping somebody will have some info on this please help winters coming....
  12. Ok so you suggest the dynavin n6 I guess I need the bose interface module also is there any other accessories I would need for the n6 install? I'm also looking at the DAB radio module and maybe the tv. Can you suggest a back up camera also?
  13. Hey Guys I posted this in another forum but not had much luck so I'm hoping somebody could help me on this : I'm looking for anyone in Birmingham Uk who could replace my blend motor in my 955 S cayenne as the blend motor which directs air to the front windscreen vents is not flowing up anymore and I believe this blend motor is right at the top of the dashboard and is a pita to get to. Any help on this please greatly appreciated. Part is 95562491101 for right hand vehicle only. Anyone got any detailed instructions on how to replace?
  14. Hi, I'm after a headunit to replace my pcm2.1 which comes with Bose in my 2003 cayenne S anyone got any feedback on having a Dynavin n6 or suggest another alternative? Thanks
  15. Found out that my oil leak was from the power steering pump plus the two pipes connected to it the high pressure and low pressure are quite corroded will need a new pump and 2 new pipes, the transmission leak is ever so slight so been advised to leave it and on top of that I'm on a search for 285/35/22 tyres anyone got any deals in the UK? :blush:
