bsh
About bsh
    Norway
    Other
    2007 997 TT
    Lancer Evo 2 680whp/750nm
bsh's Achievements
  1. Hi, Regarding the PET i have Access to, my 997.1 TT 2007 front diff have this part # 997 349 020 50. The one I have found have this # 997 349 020 51 and the seller claims it is removed from a 997.1 3.6 480 HP. He have no VIN to give me... What I have found, is that the front diff he have for sale, is from a 997.2... Anyone knows if it will fit and can be used with my car? I have also found that both 997.1 and 997.2 driveshaft flanges have the same part #, which is a good start:) Thanks
  2. I got another second hand PASM module and have been driven the car a couple of weeks without any fault messages, so it seems everything is ok now
  3. Had my car at my Porsche dealer for coding, and they told me that the second hand PASM module I bought is defective as it will not communicate with the other control units... I ordered another one today and hope this one is ok:)
  4. Thanks Loren you are #1:) Do you happen to know about a second hand PIWIS for sale, or know some website that are selling some that works well?
  5. Ah forgot that. It is a 2007 Turbo. Thanks
  6. Hi, I replaced my PASM module with a second hand module from an US car. My car is a Euro spec. I now get C156: Communic. PASM control unit (drive) from PSM, Instrument cluster and Gateway modules. Is the second hand unit faulty, or does it need to be coded? Did never had that fault code with my previous module... Thanks
  7. Hi! What is required to open TSB 9679? Homelink. Thanks
  8. Thanks for your help Loren:)
  9. Excellent info:) Where is ground point 8 located? Found a picture of it when I googled it, but it was hard to see...
  10. Ah I see:) Where is the wire A2 from maxi fuse grounded? Thank you Loren:)
  11. Thanks Loren, I think I expressed myself wrong, but as far as I could see in the relay holder, the power to the secondary air pump is coming from the secondary air pump relay (relay 10) and the power that is supposed to feed the relay is coming from the maxi fuse. Where does the +12V to the maxi fuse/relay coming from/connected to? Directly from the battery/starter? As far as I remember it was a thick brown wire about 4.0 mm2, but I could remember wrong... Thanks
  12. Hello! Anyone knows where the 4.0 mm2 brown wire to the 40A maxi fuse for the secondary air pump is getting +12V from? Thanks
  13. Ah I see. Would it be possible to coat them with some stuff to prevent this? Thanks
  14. (you should never store one of these cars with the suspension hanging, very bad for the struts). . Will it be ok to store it if the wheels are removed as there is less weight for the struts? I was planning to store my 996TT for about 3 months in a lift until I read this... Thanks
