Ddavidoff
Everything posted by Ddavidoff
  1. Haha. Figures. Glad that helped. Sent from my iPhone using Tapatalk
  2. Sounds like you should just replace them....but I know your costs are adding up. Sent from my iPhone using Tapatalk
  3. Sometimes the parts catalog can give some clues. I have not taken that apart.....yet. Sent from my iPhone using Tapatalk
  4. Try this Sent from my iPad using Tapatalk
  5. Make sure you can loosen the fill plug, before you start the drain. Sent from my iPhone using Tapatalk
  6. There are a few pics in this thread, but I didn't take any as this issue was well documented. http://www.6speedonline.com/forums/cayenne-955-957/316151-09-brake-proportioning-ignition-lock-fault-issue.html Thanks for the ECU idea. I will start cleaning connectors and checking wiring. It ran better even when warm this afternoon, so I think this may have helped. Not sure I'm 100 cured yet. Sent from my iPhone using Tapatalk
  7. Oddly enough my issues have somewhat disappeared after drying out my foot wells. I found a substantial amount of water, cleaned the drains and soldered and shrink wrapped the two crimped and taped wires that are in the left side harness in the puddle. I have only driven it once since completing the dry out and it was cold out today -4 Celsius. Will post again if my issues return or something changes. Maybe these two wires were shorting out in the moisture.... Maybe someone knows what the two wires that are crimped and taped from the factory are for? Other post mention unable to start when they corrode and become disconnected. Sent from my iPhone using Tapatalk
  8. Just looked for the common ones as I didn't have a smoke machine. Thought about building one. Maybe one day. T behind the intake and the firewall brake booster connection. Sent from my iPhone using Tapatalk
  9. Engine degreaser and elbow grease. I also use a brass brush for the tough stuff. Sent from my iPhone using Tapatalk
  10. Welcome and enjoy the Cayenne. You will love it. Sent from my iPhone using Tapatalk
  11. When you press the brake it will release a locking mechanism in the gear selector so the you can shift from Park and will relock when you put in park and lift your foot from the brake. Notice of you try and shift from park without holding he brake the gearshift is locked in place. Maybe that is what you are hearing. Mine is fairly loud as well. Sent from my iPhone using Tapatalk
  12. A good time for a cleaning as well Sent from my iPad using Tapatalk
  13. +1 on the washer bolt method. Worked well for me. Sent from my iPad using Tapatalk
  14. Interesting. I will do some research. Thanks for the info. I live in Canada so we don't see the heat like southern cars do, but this one came from Cali so that might explain it. Sent from my iPad using Tapatalk
  15. I have to agree with the while you're in there comment. Why spend all the time taking things apart to do half the job. Did mine this winter. Plugs, coils, new tubes and seals. I then decided to do the AOS and following the while you're in there idea: new vacuum lines, oil fill tube and seal, coolant tank etc.. Also tested the vacuum canister for leaks and almost did the starter, but it looked like it was in good shape. Also, had a good look over the starter power wire that is known to have issues, but mine was in great shape. Maybe it was already replaced. Also found that the vacuum line had come out of the intake plenum and the intake had sprayed oil all over the top of the engine. Cleaned all of that up and put it back together. Also found the temp sensor had been taken out of its holder on the right side of the intake. Also, changed the trans fluid and while doing that replaced the fuel filter which is in the same area. Ordered some coilovers and some new tires. Probably need a fender roll in the rear so that will be a task for the next few weeks. Sent from my iPhone using Tapatalk
  16. Changing 02 sensors would be a an expensive shot in the dark. IMO Sent from my iPhone using Tapatalk
  17. Mine is a coupe so can't be much help. Sent from my iPad using Tapatalk
  18. Mine has a brand new battery as I suspected this to be an issue. Tail gate not opening all the time, hard steering, other gremlins. All problems gone with a new battery. Good advice on swapping it out Brainz. Sent from my iPhone using Tapatalk
  19. Wow. This would be an amazing find if it turns out to solve this problem for you. I will try a swap as well. Sent from my iPhone using Tapatalk
  20. Following. Similar issues. I have done a lot of the same maintenance. I also found a few vacuum leaks which I fixed. 08 CTT You might want to check out the "stutter and hesitation" thread, as it has some good info although no solution for us. Sent from my iPhone using Tapatalk
  21. I'm pretty sure you can't buy the internal wiring harness separately. Just buy some wire and do it yourself one by one. Or replace the whole assembly. Just did the ones for my 911 996 HID's. Sent from my iPhone using Tapatalk
  22. That sounds pretty accurate, but mine is very subtle right now. Trying to deal with it before it's a major borp. Right now it just feels like a misfire. Sent from my iPhone using Tapatalk
  23. Mine has a very slight hesitation at low RPM's. I have replaced the ignition coils as well as spark plugs air filter's and have fixed the T vacuum connector at the back of the intake manifold as well as fixed the vacuum line for the brake booster. Also found some air leaks in the intake tube's which I was able to tighten the connectors on to seal up any leaks. Still similar issues, hesitation as well as low idle, it will also hunt for gears. Doesn't matter how much fuel is in it it has done it with low fuel as well as a full tank. Might pull one of the fuses next to try and isolate it to a fuel pump but thinking that might not be the issue. Took apart the AOS recently to make sure that it was functioning properly and no torn membrane so I put it back together. Sent from my iPhone using Tapatalk
  24. Same here similar problems. I'm hoping you find something soon. Sent from my iPhone using Tapatalk
