Ddavidoff
Everything posted by Ddavidoff
  1. [emoji23] Sent from my iPhone using Tapatalk
  2. Some posts talk of a brown wire with a blue stripe as the alarm wire. This is true, but please note that my car has two such wires, one directly on one of the radio connector harnesses and the other, the alarm wire, which is initially hard to find. This wire is actually connected to a pressure plate on the left hand side of the radio mounting bracket as you look at it. The pressure plate presses against the radio and when it meets metal, it sets off the alarm. With my aftermarket HU, putting loads of masking tape over the left hand side did not cure the problem. The only cure came when I disconnected (I didn't cut the wire and I advise against cutting it as it is not necessary) the alarm wire by pushing back the clip which connects it to the pressure plate. Once that is done, simply tape up Sent from my iPhone using Tapatalk
  3. Sounds like the alarm wire for the radio. Sent from my iPhone using Tapatalk
  4. Drill it out from the wheel well, bolt, nut and washer it. Or drop the suspension and replace the top hat with the one you ordered. My preference is the latter. Sent from my iPhone using Tapatalk Pro
  5. Looks like you are missing some pieces. What year? Also, can you zoom out in your picture? What does the other side look like? Sent from my iPhone using Tapatalk Pro
  6. Looks like that inner sleeve pulls out to make a press fitting. Can you pull the large part back while keeping the smaller front one in place? Sent from my iPhone using Tapatalk Pro
  7. Yep, as mentioned mine is loud as well. Alternator,starter seems a bit out of the ordinary, but I have heard about a few having problems. My theory is that it's cayennes that needed a battery for a long time which is hard on the starter and alternator. Drive shaft, rotor and pads are all wear and tear parts on the Cayenne. Sounds like nothing "major" was found. What will happen with the warranty you mentioned. Will you claim it there? Sent from my iPhone using Tapatalk Pro
  8. I have read that this can be done without the tool. Sent from my iPhone using Tapatalk Pro
  9. I should also mention I had battery issues as well. Tailgate not closing, various fault codes including hard steering, etc. replaced the battery, cleaned the terminals and all problems went away. I went with the new glass pack technology battery. Also had the water in the cabin issue, corroded wires in the driver footwell. Cleaned the drains; again search for which ones. Resoldered the wires and dried everything out with a hair dryer. Do a few of these things now and you will save yourself some headaches. Sent from my iPhone using Tapatalk Pro
  10. Does it have pdcc? If it does they wine a little and sound like a bad pump. Mine has some of the same engine sounds, a little piston slap I think. There is a known issue for scoring that can cause this. You would need a scope. I would stay on top of oil changes and make sure you use decent oil. As suggested above I did all the maintenance items on mine. Plugs, coil packs, all fluids, belt, brake flush, brakes all around and I bought a drive shaft. Just waiting for the one in it to give up. I'm getting some vibration so that won't be much longer. I also did the thermostat which was fairly easy, with the exception of getting the sleeve out. Do a search for options. There are some vacuum leaks that can be addressed, the T at the back of the intake manifold is not easy to get at but can be done. I used a brass one with some clamps. The brake booster vacuum line also cracks near the firewall. I fixed mine me with sealant and tape. I also ordered a new one, but have not installed it yet. Sent from my iPhone using Tapatalk Pro
  11. Replace them all. Sent from my iPhone using Tapatalk Pro
  12. Might want to do a seat swap to the comfort seat. I'm 6'2" and sometimes I feel too low down on the lowest setting. Sent from my iPhone using Tapatalk Pro
  13. You can pull the relay and jumper it yourself to see if it will run. You can also test pressure at the fuel rail using the jumper and can disconnect the fuel line and spray the fuel into a container to check fuel delivery quantity. Sent from my iPhone using Tapatalk Pro
  14. Changing position is normal operation. Sent from my iPhone using Tapatalk Pro
  15. Did you check the bonnet micro switch? Sent from my iPhone using Tapatalk Pro
  16. I have heard of the bushings in the arms seizing up. Does the motor run when not connected to the arms? Sent from my iPhone using Tapatalk Pro
  17. Dealer only. Unless you know someone with a PIWIS, but that's unlikely given the price. Sent from my iPhone using Tapatalk Pro
  18. Sent PM with some advice. Sent from my iPhone using Tapatalk Pro
  19. Yours looks a bit different than mine. Year and model? Sent from my iPhone using Tapatalk Pro
  20. There is a clip inside that you can't see at the top center. Gently pry and slide a credit card into the crack to separate it. Zoom on this pic and you can see it at the top. Sent from my iPhone using Tapatalk
  21. Old thread, but just received some Yellow Speed Racing coilovers that I will be installing this weekend Sent from my iPhone using Tapatalk
  22. Page 121 in the link I sent. They could be different front and rear. Best you match the parts to the diagram. Sent from my iPhone using Tapatalk
  23. http://www.porsche.com/all/media/pdf/originalparts/en/E_997_KATALOG.pdf Sent from my iPhone using Tapatalk
  24. It looks like 6 and 7. I tend to over buy and then return if needed. Especially on cheap parts like the connectors that seem to be broken here. If you speak the the parts department and show them the pictures you should be fine. Also you can search the internet for 997 Katalog and you will be able to find a diagram of all of the parts along with part numbers. Sent from my iPhone using Tapatalk
