Schnell Gelb
Everything posted by Schnell Gelb
  1. We've discussed this many times elsewhere but you got the answer in one Post already :-) There are inexpensive test meters that will show "S.O.H." and "S.O.C." (google) but just buy a new battery AGM imho. You also need a Cteck MUS 4.3 .Amazon .Porsche also sell it for x2 ! Use it over summer to try to use it to revive your old battery The Cteck will 'pulse' and this may improve the sulphation The SOH test will confirm. Use the old battery on your old maintainer next winter as your emergency slave battery. Plug the Cteck into the cig lighter socket over winter. Some really smart P-Car experts do this with their customer cars "-)
  2. Vario Cam solenoid swap in Car Please refer to this thread on Rennlist : Then the details are: This applies to the Porsche M96 with Variocam. Later Variocam Plus is not quite the same. This is a WIP that I hope others will improve. The info is gleaned from dozens of posts which I have used to put the basics in one place. Now it is your turn to improve it, add photos , links and most important – corrections . Here is my related Thread: Check the engine diagram to get the correct terminology.Confusing a Author Schnell Gelb Category Boxster (986) - Common Fixes and Repairs Submitted 03/24/2017 08:53 PM Updated 05/02/2017 12:16 PM
  3. Please refer to this thread on Rennlist : Then the details are: This applies to the Porsche M96 with Variocam. Later Variocam Plus is not quite the same. This is a WIP that I hope others will improve. The info is gleaned from dozens of posts which I have used to put the basics in one place. Now it is your turn to improve it, add photos , links and most important – corrections . Here is my related Thread: Check the engine diagram to get the correct terminology.Confusing a Variocam actuator with a Chain Tensioner is a common mistake. When in doubt use Porsche part numbers only. Diagnosis: Without Durametric or PIWIS you will not be diagnosing.You will be guessing. Beware of cheap Fleabay knock-off cables. They run very old ,often corrupted versions of the software. This causes misdiagnosis or failure to actuate components. They have no Tech Support.A very expensive mistake to make.Pelican sell the genuine Durametric cable. Make sure you don't have other faults caused by old O2 sensors ,old plugs, vacuum leaks. Check Coil ground for 1.2.3 on the 6mm stud near the AOS is good. Clear all codes. Durametric at idle produces no codes. Increase idle speed to 2000 rpm and the 1341 reappears. This is the target identified.But the big diagnostic problem that I never solved is how to distinguish between a failed solenoid and a failed actuator without taking the cam cover off and more. Using the Durametric cable, “ACTUAL ANGLE” for Bank 1 shows no advance - a flat line or lots of small oscillations but never reaches a # near 25 degrees. Bank 2 shows 25 degrees and deviation is rock steady and within limits(6 degrees). This is the general target confirmed. Without Durametric at this stage ,you were lost ! You clear the codes and at idle activate (with Durametric) the solenoid for Bank 2 .Hear the change in engine sound? Yes. Try same on Bank 1 – no change - double confirmation. Seems like the Variocam solenoid is not functioning or the actuator ,or both ? Or the wiring or the DME. Some expensive components here so let’s do some tests. Tests: You will need to make some test cables to use in each of the tests below.AS noted below you can hack some male & female Bosch EV1 connectors to fit.I made dedicated test cables for each test to avoid the risk of arcing between probes or alligator clips. The man problem is access. On a Boxster, Bank 1 is the worst. 1. Disconnect the plug for the variocam solenoid. Test the solenoid - you are looking for approx..13.5 ohms across the 2 contacts (not to chassis ground!). 2. At the mating part of the solenoid wiring connector use a MultiMeter on the 20V scale. Connect ONLY between the 2 contacts. Do NOT connect to chassis ground. You are looking for around 10.5 volts (assuming a fully charged battery) . Yes one of the contacts is battery voltage and the other is a switched (3v)ground via the DME – but that is needlessly complicated to get into at this stage.Just look for 10.5 volts. If you get no reading - is the engine up to full operating temperature? 3. With the engine warm & idling , connect the solenoid contacts via a 12v battery (from a cordless power tool?) The engine note should change because you are advancing the valve timing on only this Bank by 20 degrees. Remove the 12v battery connection. Engine reverts to normal idle. You can make the connector and leads from an EV1 connector if you cut back the shroud/casing.A word of caution about the polarity of the test connection directly to the solenoid. First -use a fuse in the test cable . Check Bentley for the wiring diagram and be very careful to follow the same polarity. In theory it should not matter but Porsche used polarized connectors ,so we should also? A related test without Durametric is to use the same 12v source to activate the solenoid with the engine OFF, in a very quiet workshop. If the solenoid is working you should hear a 'click' every time you press the MOM switch on the test harness.This is significant because you need to understand what makes the click sound . Is it the solenoid or is it the sound of the actuator moving the timing chain or both ? I ask this question because the solenoid on the suspect Bank passed the resistance tst with 13 ohms- identical to the perfect bank(2). But the external 12v source only producced a click on the perfect bank2). The same test on Bank 1 was silent. 4. Next connect an extender cable to the supply-side connector for the Variocam solenoid.This is the wiring loom that runs above Bank 1 and connects to the DME. The terminals are roughly EV1 size but the standard EV1 shroud is too large. I used the pins/connectors from an EV1 Bosch 1 287 013 003(female) and the corresponding male pins to make an extension. The male pins could be 'hacked' by removing one leg of a 'red' fork crimp connector. Run it to the driver’s seat area. Put a Noid bulb in it. Start the engine and run to 2000 rpm. Does the light illuminate? Instead of the noid light you could use a multimeter on the 20v DC scale - to see if it flashes 10+v? This might work ? Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI Ahsai mentioned using a 12v 6w ‘peanut’ bulb instead.I used a Noid light because I had already made test harnesses thet acceted a Bosch Noid. By now you should know if the solenoid is defective or if there is a wiring /DME fault. One of the links below shows the culprit as a burnt transistor in the DME. But let’s say the wiring/DME test O.K. Note: I fabricated custom test leads for the MM to check supply voltage I also fabricated custom power jumper leads for the solenoid. These included a 10A fuse and an MOM switch. 5. There is one other very creative test kindly suggested by Jake Raby. Connect with a jumper between the 'good' bank and the suspect one.Be careful to follow the same polarity !! Consider using a fuse and MOM switch in the test cable you fabricate. Needless to say - check all your test cables for continuity before use and avoid crimp connectors - solder them ! It is a final, positive elimination of variables.This is a good test to indicate problems with the transistors in the DME(thank you Ahsai !). This would have been indicated in the prior test that measured for 10.5 volts at the Variocam connector from the DME. Note on the 5.2 DME - transistor and/or solenoid failures were more common for reasons unknown. There is so much work involved in getting to the defective unit that people often replace both the actuator and solenoid ,when only the solenoid was positively identified as defective. Conclusion: the solenoid &/or Variocam actuator are defective. Repairs This video on re-timing gives an idea of the access problems: https://www.youtube.com/watch?v=nE_X27JSTyE Now this gets expensive and time consuming. 2001 Porsche Boxster S Convertible - Camshafts & Timing Chains - Page 2 The solenoid needs to be replaced, or the actuator repaired or both. You need the special tool # 9624 /P253 to hold the cams in a safe position while you do this. Read the details elsewhere . Ignoring it may break a camshaft ! The link in French below(google translate) has the dimensions for the tool. I had already bought the complete Baum engine tool kit in a case. variocam - Tuto changement solénoid variocam On Bank 1 for the Boxster the access is so restricted some mechanics cut an access hole in the firewall of the trunk ! Certainly remove the wheel ,header, plates and anything that gets in the way ! Check elsewhere for the special sealant and gaskets required and the ‘while you are in there’ jobs like spark plug tubes/seals. Read Wayne's write up project again! This is the best write up/photo of timing the M96 by Insite, DIY: Setting Cam Timing on M96 Lock the engine with the 8mm bolt in the c/s pulley and lock the cam with the special tool 9624 or ‘French’ equivalent. Place all bolts carefully in a cardboard template (see French link again !) Some of the bolts are different lengths and if you muddle them you will be helicoiling! Remove cam cover. Note no gasket ! But a lot of sealant to remove with a PLASTIC scraper. Find the instructions on how to lay a bead no more than 2mm wide when replacing the cover. Use the correct sealant ! See Wayne’s article for more. Porsche Boxster Camshaft Upgrade / Chain Tensioner Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article 2001 Porsche Boxster S Convertible - Camshafts & Timing Chains - Page 4 Replacing the $200+ solenoid is now simple. Careful not to crimp the wires during reassembly. Now you can do a visual check of the actuator. Connect 12v to the solenoid contacts. Does the actuator jump about 1/8 “ ? Can you feel the click in the solenoid. So is the solenoid defective or the actuator? If you need to remove the actuator it gets more complicated. The actuator needs to be compressed a little to remove. In theory you can use 5mm x 0.8mm (verify !) threaded rod and deep nuts on the older Boxsters. The newer (post 2000?) changed to LEFT hand threads ! I found the necessary L.H. parts- Brass rod, L.H. die nut, L.H. nuts on EBay but waited for months for them to arrive from China ! In theory you can use high quality zip ties but access is so difficult that you may struggle to achieve enough compression of the actuator. Much easier with the engine on a stand ! On the bench you can repeat the test for the actuator and confirm with a new solenoid. If the actuator seems weak or can be easily compressed or is locked rock solid -it perhaps can be dismantled and cleaned- but I could find no info on this. If it has high miles it may be better to replace it ? If you are curious about repairing an actuator,no,it can't be done -see here: http://forums.quattroworld.com/a8/msgs/83599.phtml This is interesting because it hints at a diagnosis - an oscillating part that would produce an oscillating readout on the Durametric graph. It is a pity Audi actuators do not fit. They are $200 or less ! The part # for the complete assembly for Bank 1 is : 996-105-051-58 Bank 2 (4.5.6) is 996-105-053-58. Do not confuse - just 1 digit difference.Note - these numbers supersede prior lower numbers.Be careful to confirm if the actuator you buy does/does NOT include the solenoid. Some sloppy vendors list the part number for the combo actuator+solenoid but do NOT include a solenoid - if you study the very fine print in the parts diagram alongside their ad.Be sure you order correctly - these $1000+ parts are often not returnable ! Tests with the camshaft cover off Before you just replace parts here are a few tests to do. First watch a video to see what it should look like- start at 5minutes in this one: https://www.youtube.com/watch?v=ml5wltlM-cw Check for slack chains. It may be that the chain tensioner(not the Variocam actuator) has failed. If the engine has just been rebuilt, perhaps the new chain tensioner was not installed correctly. Use the solenoid test lead to make the actuator 'jump'. The actuator should jump in the direction of the crankshaft when you hit the Mom button on the test lead.At rest it moves the opposite direction.See video cited above. Suppose the Solenoid Passed the 13 ohms test, failed the click test and the actuator fails the visual test with the MOM switch. Which part has failed - the Actuator ,the Solenoid or both? Suggesting that you substitute a known good solenoid is probably impractical. You may have to just use probability and buy a new one and try it. If the actuator still fails to jump, even with a new solenoid, you are going to have to remove the actuator and test it on the bench. In theory you can try to purge the oil out of it and look for debris or blockage. But realistically ,after all this work it is probably better to just buy a new one.BTW the pin on the Solenoid should jump about1/16".
  4. I shall try to remove the camshaft cover with the engine in situ. I am currently trying to research the subject . For others following this Thread, if you have a 'while you are in there' list of engine&trans-out jobs, it is an easy decision - take it out. But I have just had it all out and did everything .Or so I thought. My hack idea is to remove the front engine mount, both transmission mounts and both headers while the engine is supported from above and below.I shall then try to push the engine over to create the space to remove the camshaft cover. The car is up on a Mohawk 2 post lift and I'll use an old Wudel transmission jack and the HF engine support bar. I have never read of anyone doing this. There may be a very obvious reason for that. Hopefully JFP will give a quick verdict on the proposal.Others have mentioned just lowering the engine a little by removing the front engine mount and rear wheel. Grateful for any shared experiences for this procedure. This link I just found suggests less fuss required than I had indicated above:
  5. All those test harnesses came in useful. 1. connect a multimeter to one Bank wiring harness at the solenoid connector(NOT to Solenoid side of wiring) set to 20vdc scale 2. connect a Noid light with another test harness to the other Bank. Connect Durametric ,key on engine off. Activate Bank 1 & /or 2. Nothing. Ugh ! Start engine -nothing. Run engine for a few minutes.Accidentally leave Durametric Activating Bank 1 & 2 camshaft advance. Blip throttle to 3000 rpm. The Noid lights up (4 ohms btw) and the Bank 1 voltage spikes to 13+v. So we have no DME problem and no wiring harness problem. We(I) did have a misunderstanding about the ability of Durametric to operate the Camshaft advance key on Engine Off.Others who follow this please note that you have to run the (my?) engine for a few minutes before the Camshaft advance circuit ' wakes up'. Still no click when I use an external 12v source to activate Bank 1 Actuator.Solenoid on Bank 1 still reads 13 ohms. So one problem is the actuator .When I remove the Camshaft cover perhaps others will be revealed. Since the Solenoids are more likely to fail (except for me!) than the Actuator, I'll buy a new Actuator+solenoid and keep the old(good) solenoid as a spare. But only after I bench test the old Actuator. Thanks for hanging with me on this guys.
  6. Yes.Thank you for the gentle reminder to be systematic. I'll postpone the dreaded dismantling and do that .Logically your hint makes great sense. I have a Noid light that will fit into one of the many test harnesses I made because the Noid has EV1 type pins.
  7. The test with the MOM switch+external 12v power source direct to the solenoid was a failure. Repeated pulsing of the MOM switch produced no response on the trace from Durametric Actual Values. I am reluctant to operate the MOM switch for more than a few seconds in case the 12v overheats the solenoid. It is intended to operate at 10.5v (iirc a post by Ahsai), not 13v from a motorcycle battery. The only new data point is that immediately after one restart in the MOM-switch tests , The Deviation on Position 1 was much reduced - just 9 degrees instead of the 'usual' 14.9 degrees. When I operated the MOM switch , Deviation jumped back to 14.9 deg. & remained(as usual) rock steady. It seems unavoidable to remove the camshaft cover for Bank 1 and inspect. That is a very tedious task that I can enjoy over the weekend and report back. I try to predict the surprise that will be revealed in such cases because it is a good (or humbling) test of your understanding of an issue. I cheated by researching many other posts on the "1341" but none had a hint of what this specific issue is. The root cause is probably engine assembly error ! To recap , there are 2 related issues on Bank 1 only - Bank 2 is perfect on this just rebuilt engine: 1. Deviation of 14.9 degrees at idle at Position 1 2. No change in Actual Values of Camshaft advance with increasing r.p.m. or Activations/prompts from Durametric or an external power source. For those following this in future, this is the stage to order the oddball left hand threaded studs and nuts to compress the Actuator for my 2001 S. Older cars had right hand thread. Also prepare your 'while you are in there' list - spark plug tubes,oil pump seal,coils(?) ,plugs. And if you are working on Bank 1 - the AOS and it's corrugated tube. Mine are all new.
  8. The difficulty in refueling is a common problem caused by possibly a vent valve malfunction. Suggest you search for the diy for that.Pelican have one iirc.
  9. Thank you both. I'll get to work this evening with more tests and report back. If the fault was the Crankshaft Position Sensor, that would produce problem on both Banks not just Bank 1 ? Unless it was a wiring problem. The DME theory - that 'should'? also cause the same problem on both Banks? Unless it was a wiring problem. An interesting test - I have a 12v source to connect direct to Bank 1 solenoid.It has a MOM switch & fuse on the test harness that I can operate and watch the Durametric trace. That may indicate I have a lazy/sticky actuator? The Bank 1 solenoid reads 13 ohms but produces no "click" from an external 12v source like Bank 2. I am trying to be thorough and systematic with the tests because once I start dismantling things - it is too late for some of these tests. This time I'll let the engine warm up at idle ,no revving to 3000 rpm to activate the cam advance. That should give a better observation of the peculiar camshaft deviation readings on Bank 1. Then I'll stop the engine and connect up the MOM switch harness and observe the trace for Bank 1 Actual Angle. I speculate it will be a small saw tooth profile as the solenoid struggles to move a sticky/plugged/leaking Variocam actuator. All idle speculation without more diagnostics.More later today I hope.
  10. I did the test that JFP suggested above and Bank 1 looks perfect.So why is there a cam deviation at idle of 14.9 degrees at Position 1? Surely that would be visible? Fortunately I kept lots of notes and diagrams from when I rebuilt the engine so I was able to compare the orientation and position of the 1/2 moon and notch now to my previous records. I tested the positions of the Exhaust cam notches and the Inlet notch over 4 successive rotations to make sure. For anyone trying this with the engine in the car - you need a rack and very good inspection lights.It is very obstructed unless you take off other parts(exhaust for example). Tomorrow I'll fit new green plugs and do the electrical tests that Ahsai suggested. Then we'll have some useful data to work on. The suspects are : 1. Variocam actuator +/- solenoid - very expensive and requires major ,awkward dismantling. - but at least it can be done without removing the engine :-). 2. Wiring harness to Bank 1 ( I did some clumsy electrical work on the SAI harness and perhaps I damaged nearby wiring). 3. Camshaft position sensor, Bank 1. I have not read that these fail so this seems unlikely'.Is it possible to make a mistake assembling the cam position sensor ? The combination of Code 1341, no cam advance but a huge cam deviation (14.9 degrees)at Position 1 is a weird combo of symptoms.Bank 2/Position 2 is perfect per Durametric. Thanks for any suggestions as always.
  11. Thanks Ahsai. I'll do the test work this afternoon .So many details of life seem to interfere with Porsche repair time :-).
  12. Thanks JFP. Here is a link to help others see what we are referring to on a 5 chain M96.It is a Thread started by Insite on camshaft allocation with excellent photos and descriptions: http://986forum.com/forums/performance-technical-chat/26418-diy-setting-cam-timing-m96.html This is one of several YouTube videos showing the work & tools that may be required: https://www.youtube.com/watch?v=nE_X27JSTyE
  13. Duncan, Thank you for your suggestion. I remember your epic thread with Imo in Canada and the burnt transistor in the DME. He even located and fitted a replacement transistor iirc. Incase anyone following needs the "IMO" transistor for the DME, it is very difficult to find as a spare part. Here is a link for it - a BIP373 Coil driver: https://www.diyautotune.com/product/replacement-bip373-coil-driver-q16/ I have not completed the exact test you propose, so thank you for the suggestion. I did make a special harness with a modified EV1 connector . It fits on the connector for the solenoid . This is hardwired to a dedicated pair of leads to a cheap MultiMeter. With the MM set at 20vdc ,Bank 1 never shows any voltage on the MM, regardless of engine speed or coolant temperature.The same test on Bank 2 shows 10v when the camshaft timing advance kicks in. The custom harness is long enough to reach into the cab so it is easy to read and idiot-proof. But I'll certainly try your test with the 3W bulb to simulate a resistance. In previous Threads you explained an external 12v supply test.This makes the Bank 2 solenoid click. Bank 1(with the suspect timing 15 deg off) is silent. I made a dedicated harness for that test also. I made a 3rd test harness to go from the solenoid connector on one Bank ,across the engine directly to the solenoid on the other Bank. I try that also. As you suggest , I am trying to eliminate DME and wiring problems by substitutions. JFP's test suggestion will be embarrassing if it confirms I got the timing perfect on one Bank and failed on the other. Regardless, I'll confess so others can learn from this. Thank you both for your helpful suggestions.
  14. Thanks JFP That is a great start. Btw it s a 2001 S - so a 5 chain. So I need to look for 1 slot or 2 ,please? I fixed the +/- 6 deg mistake in my Post.Thanks.
  15. I need some advice on what further tests to do before I start disassembling the camshaft. The code is "1341 = Camshaft adjustment Bank 1 below limit value." But I think this is misleading. Normally , this would be just a failed Solenoid or Variocam actuator. Btw ,these comments apply equally to a Bank 2 fault. But if you look at the Durametric data below ,there is a hint of a cheaper but much more stupid error. I recently rebuilt the engine. It runs beautifully. But has only run a few hours because I can't get rid of the 11341 fault code to get a Smog Test. The Actual Values alone are clear but not when you look at the Deviation, not so much. All values are with a warmed up engine(fans kicked in several times) 1, Actual angle at idle rpm, Bank 1, 0.3 to 0.8 deg. At 3000 rpm only 2 degrees ! Bank 1 solenoid measures 13 ohms(perfect) but will not activate with Durametric , nor with the Ahsai 12v battery test. 2. Actual angle at idle rpm, Bank 2, 0.02- 0.2 deg . At 3000 rpm 20 degrees - perfect. Bank 2 solenoid can be activated by Durametric or by the external 12v source. 3, Deviation Position 1 at idle is 14.9 deg and stable - it should be +/- 6 deg ! 4. Deviation Position 2 at idle is zero and stable- 0.00 ,nada . Please check my logic/knowledge here because I need help. My theory is that I must have failed to time Bank 1 correctly. It is so far out that the Camshaft Advance will not activate ? The stable deviation is because of new chains,IMSB , chain rail pads and tensioners. So I need to re-time Bank 1. If it seems to be perfectly timed - look for a Camshaft Position Sensor problem ? I'll bench test Bank 1 Actuator to see if it has a firm 1/16" 'jump' .If it is doubtful I'll replace it because of the time involved. Fortunately I have the cam tools and Insite's helpful classic post on timing the M96. Before I start dismantling , what else to test? Maybe connect between the Bank 2 harness and Bank 1 to try to activate the camshaft advance (Jake Raby suggested this in a related Thread) I get no reading on the Multimeter when I connect to the Bank 1 harness but do get the correct voltage (10V) on Bank 2 . No, I did not connect to chassis ground(thanks Ahsai!) This is an interesting example of needing to use 2 different(but related) readings from Durametric to make an accurate(??) diagnosis. If I had just fitted a new Actuator +solenoid($1000 ! ) ,the basic fault may still be present.And I would have to repeat all that dismantling again ! So thanks for any suggestions of more diagnostic tests.
  16. Thanks Mike, As I suggested previously " Just buy from Sunset ! " Just phone them .Give the VIN & No problems. The difficulties began with Interchange/crossover numbers.Same story with Heat Exchanger seals and O2 sensors.
  17. For what I spent on this one simple issue I could have bought at full retail from the local Porsche dealer several times over ! And not to mention the time . Hopefully others will benefit from my experience and measurements- if the tubes are under-size and out of round there is no seal that will work ! Utterly useless parts .
  18. I now have 3 sets of spark plug tubes and seals. So I measured them all carefully to identify the cause of the leakage. The leaking tube+seal combo is under-size and out of round at the inner end. The groove in the leaking tubes measured 26.45mm at the inner end - over 0.5mm smaller than the OEM item.Obviously this measurement varies according to the location in the groove you choose because it is out of round ! It is somewhat oval in cross section and fits into a perfectly round hole in the camshaft cover! No amount of seal swapping could have corrected these 2 defects at the inner end of the leaking aftermarket spark plug tubes. At the outer end, the groove was oversized by an even larger amount. No wonder I had a hard time removing the tubes ! Just buy from Sunset !
  19. " Also found the temp sensor had been taken out of its holder on the right side of the intake. " There may have been a reason for that . In doing so, it ensured the engine compartment cooling/purge air fan came on at a lower temperature and stayed on for longer. I am not recommending this but have read that it is a popular hack/mod with some others. The temperatures under there are so high during heat soak, I presume that accelerates the degradation of some plastics that bedevils the older M96. And there are a lot of inaccessible ,crucial plastic parts under there as you've recently discovered!
  20. If the seals are new (like mine) or have sealant on them, it may be impossible to remove the tubes with the transom plug. I had to use the 'bolt+washer" tool because the outer orange seal was so tight. If you crank up the transom plug too much with brittle tubes ,they may break.Then you have the anxiety of extracting all the broken plastic . Some have mentioned that the 1" transom pug was too small in diameter. Wrapping it with sandpaper is reported to be helpful. The washer+bolt method is not mine. The first diy guide+photos I noticed was in a post by Healthservices here: http://986forum.com/forums/diy-project-guides/52150-spark-plug-tubes.html
  21. I just did a similar job. 2 suggestions. Check the spark plug tubes for oil leakage from the inner seal. Or you will have to repeat all the work. The seals are cheap and quick to fit when the coils and plugs are already out. There are some helpful comments.cautions and explanations from JFP here: If your new tubes leak 7/or are hard to remove, here is the reason i found. The inner end of the tubes may be out of round ! The outer end may be oversize. I used the aftermarket tubes that came as a part of a "Conversion Set'. The replacements from Sunset were perfect. The other hint is to examine the coils in very bright light when they are clean and dry. Only after this step did I notice the beginnings of hairline cracks on all 6 coils.They were also a little discolored. The resistance test that Loren kindly mentioned previously showed the coils were electrically perfect. I had misfire on all 3 cylinders on Bank 1.The new coils+ plugs+tubes fixed it. There is an upgrade to the old coils that also requires longer bolts - the 'head' of the coil is thicker. So I just replaced them on a 'while you are in there' basis .
  22. For guide pins - you can also use high grade metric all thread but be aware the threaded holes in the crankcase halves are not all the same diameter. I left the threaded rod in place (with green or maybe blue loctite) and then fitted deep , high grade nuts (+ green Loctite) The other oddity is that the OEM bolts are significantly shorter than the threaded depth of the holes allows. So my custom studs are significantly longer than the bolts were. But do not let them bottom out in the crankcase. Good idea to chase and clean the threads before you put the threaded rod in. The other little aid was to very lightly 'dress' the leading edge/corners of the input shaft to help it slip in. And if you didn't get the centering of the friction plate absolutely perfect , none of this will help !
  23. " All I needed was a ~4 in long 10mm ring-wrench " Thank you for taking the time to show us what special tool worked. The Pelican kit should include such a peculiar wrench - then there would be a really useful "Pelican way" ! The correct terminology may be a "Stubby" 10mm wrench -Mac Tools have one : MXS102KS
  24. How many of the "leaking spark plug tube seal" complaints are caused by fitting the 3,2 seals to a 2.7 and vice versa,I wonder? Or out of spec seals. The vehicle is a 2001 S., so 3,2l engine.This is the appropriate Pelican page:http://www.pelicanparts.com/catalog/SuperCat/1048/POR_1048_ELIGNT_pg1.htm#item3 Pelican lists the same part number & dimensions a for a 2001, 2.7l engine. I mention this to alert others to a potential problem.Pelican sell both an aftermarket product(Victor Reinz) and a Porsche part. To help others follow JFP's advice, the PET reference to the seals and tube I just found is : Page 001, KAT 20, UPD 248, Illustration # 103-00. The Position numbers are 28 and 29. The part numbers I found are below but please verify. I have noted in brackets the dimension of the groove each seal fits into on the tubes- so you can see how much each 'o' ring is stretched when new. My large O rings were a sloppy fit after less than 1 hour run time ! The inner seals were tight but possibly too thin. Sunset Porsche time! 999 707 343 40 (inner) 25,07 x 2.62mm - (27mm) 999 707 215 40 (outer) 27.94 x 5.33mm - ( 29mm) Here is a link to Sunset Porsche at which you can use your Renntech Member discount(must donate to Renntech to get this member benefit/discount). http://www.sunsetporscheparts.com/porsche/911/99970734341/2002-year/gt2-trim/3-6l-h6-gas-engine/engine-cat/engine-parts-scat/?part_name=flange-o-ring I hope this helps others avoid the waste of time and money I incurred.Thanks to JFP for supplying all the missing knowledge.
