blueline
About blueline
  • Birthday 10/13/1957
Contact Methods
  • Website URL
    http://
  • ICQ
    sebring florida
    1999 carrera 2004 cayenne s
  • Future cars
    cayman s
    none
1,351 profile views
blueline's Achievements
  1. 1999 c2 85000 no problems window reg just done week ago right side tie rod and rear left lower link
  2. Since you are only removing the air intake muffler and making the air filter box larger the small hose is blocked forcing all the air by the air flow sensor.
  3. After changing the window regulator now the air bag light refusess to go out every connection is ok. any idea how to reset the light please my car is 99 c2
  4. The left side window on my 99 c2 makes a rattling sounds as the window goes down any idea what is causing the noise sound like peebles in the window.
  5. First off - it's a "tie" rod. Second, you can get pretty close by trying to duplicate the current installation, but not perfect. If you have good tires and care about the handling, get an alignment after replacing it. Also - you should really replace both, not just one. Thank you i have get close because i have drive 30 miles for a alignment shop, I guess i marked the location with paint Or..., just count the number turns when removing it and screw the new one in the same number of turns:) ... You will still need alignment!!! s Thanks sounds like a good plan
  6. First off - it's a "tie" rod. Second, you can get pretty close by trying to duplicate the current installation, but not perfect. If you have good tires and care about the handling, get an alignment after replacing it. Also - you should really replace both, not just one. Thank you i have get close because i have drive 30 miles for a alignment shop, I guess i marked the location with paint
  7. I have to change the outer tire rod in my 99c2 can i marked the the spot to returned to the position now any tricks or ideas. without messing the aligment or as close as possible.
  8. Dummmmb question do you have a illustration on how to use the tool please
  9. Kind of dummmmb question do you have illustration how to use or set up the tool please
  10. Find another shop. The rack does not need to come out to replace the outer track rod. I didn't take the protective cap off before snapping the pics so you can't see the threads of the ball joint. Thank you i will order the part
  11. The mechanic in a local aligment shop claims that the right front tire on my 99 c2 has play side to side and the steering link need to be replace and the rack has to be remove to change the part. question is that part 2 separate parts do i change the portion that goes to the tire side or the inside part he claims that causes the car to pull to the right . Which part is bad in your guys opinion?.
  12. thank you a gent as always
  13. I need the part number and the best place to buy the plastic part the has the track to mount the righjt headlight on a 99 c2 the rear part that hold the plug is broken Thank you
  14. All done in the setting the guy did a outstanding job setting the specs two hours $106.00 for 4 wheels car rides way better he found the setting off in the right side and left rear.
  15. Thank you going in the morning :renntech:
