Zuffenhausen955
Zuffenhausen955 last won the day on November 24 2024
Zuffenhausen955 had the most liked content!
    Palm Desert, CA USA
    2005 Porsche Cayenne S
  • Future cars
    911 Carrera 4S
    1985.5 Porsche 944
    1986 Porsche 944 Turbo
    1987 Porsche 944S
    2006 Porsche Cayenne Turbo
972 profile views
Zuffenhausen955's Achievements
  1. So, is your custom tool handle facing UP or DOWN inside the catalytic compartment?
  2. How were you guys able to get it from below? The steering shaft is in the way, from behind and beside the driver side flex pipe entry! From top, there is only less than 15mm space to reach or see anything. I'm stumped. 2006 Cayenne Turbo.
  3. What does it mean when dash warning shows, "Rear Hatch Open" every time I move forward from dead stop?
  4. Cayenne with air suspension has an air line, in-line filter, to clean the incoming pump air. If this filter comes off the mounting "straw" off the bank1 (passenger) air box - the P2096 code will manifest itself.
  5. Now, let's get to how we can all prevent water intrusion in the first place...
  6. Loren, can you give me the part numbers for items in your exploded diagram? 1) 23/24/25 2) 30-32 3) 40 Thanks in advance!
  7. Loren, can you give me the part numbers for items in your exploded diagram? 1) 23/24/25 2) 30-32 3) 40 Thanks in advance!
  8. Does a "pending P0421 DTC " prevent from setting evap, SAI and catalyst monitors? I have driven 1000 miles and the three pesky I/M readiness monitors still has not set!
  9. If the return spring broke(near caliper side) will the shoes slightly grind-up against the inner rotor? I have been trying to diagnose this annoying "whump-whump" sound for 3 weeks now!
  10. Loren, are the brake shoe return springs replaceable? I think one side of mine broke, as I heard a POP when depressing the parking brake pedal once. Now, the left rear wheel makes a spinning noise from 20-45mph. It sounds like a out-of-balance tire, but the tires has been changed 3 times already....
  11. Thanks! Where should I start looking for grounds?
  12. Loren, Where are the fuses for the 955 Turbo cornering lamps? Mine are both out and bulbs are brand-new. Lamps are new Valeo units. The left side bulb burned out but dash message indicated to "check right cornering lamp." Now, both don't work. Could they be pigtail harness, ballasts.... or, something more sinister?
