dapopa9
Everything posted by dapopa9
  1. 2011 958 Turbo Air Suspension will occasionally store error code "257 Pressure sensor, signal line short circuit to B+" when raising to higher level. Any idea what part may be causing that issue? The air suspension still works and will quickly raise/lower to all levels despite the error. Also no signs of anything leaking. I recently replaced the rear air struts and air compressor and they seem to be working well except for this occasional code.
  2. Any luck getting this fixed? I'm having the exact same symptoms. Dash indicator comes on, air comes out the hose for 1-2 seconds, and then nothing. Air suspension still works fine. I had a flat tire that I was airing up fine for a couple minutes then it just stopped - I thought maybe it just needed to recharge or something however that was a couple days ago and it still doesn't work today. Only difference is I still have the original stock compressor in my CTT.
