claudiu
Everything posted by claudiu
  1. Herewith my promised feed-back: Using Loren's instructions, my mechanic has yesterday positioned the left exhaust pipe in the correct spot, the two pipes are now perfectly symmetrical, thanks again dear Loren.
  2. Many thanks dear Loren for your super-fast response, that I shall pass on to my mechanic. Hope to be able to provide positive feedback soon...
  3. I know it might sound petty, but I noticed a few weeks ago that my left exhaust pipe in my 2000 C4 was lower than the right one by about 2 cm and I do not have a clue how this could have happened, but I recently had an air/oil separator and the water-pump replaced. To fix the sagging exhaust pipe, another mechanic removed the tailpipe clamp which was rusty with great difficulty and replaced it with a new one, adjusting the height to be in line with the exhaust pipe on the right. However, whilst level on a horizontal plane, the left exhaust pipe is sticking out by about 1.5cm (half an inch) in a vertical plane towards the rear of the car. Is that normal, are these pipes meant to be asymmetrical, or can they be adjusted further, please? The mechanic said he could not push the left exhaust pipe any further in, neither pull the right one further out... Please help!
  4. The C4 is the business, isn't it?
  5. I have had a similar problem relatively recently. Mine is a C4 2000, so I suspect the same cause might be behind the a/c failure in your car, i.e. one of the two small radiators/condensors behind the front bumper must be leaking. I have replaced both although only one was leaking and it cost me around £500 but the work was done by an a/c expert, not by the Porsche garage. Prior to diagnosing the leak, the expert introduced a green fluorescent dye. Good luck!
  6. Daily driver, C4 2000, at about 45,000 miles air conditioning condenser leaked, battery went flat but otherwise no real problems (some irregular revs at starting till sparkplugs were changed and some squeaking noise from the belts on reversing after washing the car or raining). On the whole, a great car!
  7. So I'll need a new windscreen as well to get rid of the interference...interesting!
  8. What a coincidence! I have also replaced the battery this weekend, having gone flat, but there is no chirping. However, I didn't know about the trick with the key in ignition, hence I have been almost totally deafened by the siren till I got help over the phone from the Porsche garage...
  9. My helmet is off as well! Well done!
  10. 2000 C4, nothing wrong with the engine at 45,000 miles, had to replace recently both air con condensers due to a leak in one of them (the initial quick fix of regassing the system proved futile) but otherwise hardly anything to complain about. The pleasure I get from driving it and showing off in it is immense!
  11. Happens to my 2000 C4 as well, but I'm not too bothered...
  12. I realised later on that I had pressed the car key in my pocket against the side of the chair I had sat in and the radio signals from the key activated the unlocking of the door and beacause the pressure was applied for longer than a few seconds the windows also came down You mean I can open the windows using my remote? I have a 2001 US version. What do you have? Mine is a 2000 Carrera 4. Richard has already answered your query about actioning the windows through your remote, and he is spot on.
  13. I'm very happy with Dunlop 9090, but I have never taken my 2000C4 on the track...yet!
  14. My Dunlops 9090 are fantastic, no vibrations, no noise and I think a Porsche is worth matching tyres, although I do not think that having a different brand on the front from the rear should matter as regards vibrations....but wheel balancing does!
  15. It's happened to me in slightly different circumstances. I was at work and when I went to the car (2000 C4)to drive home I found it unlocked and both windows down. I phoned Porsche garage and left them confused. I realised later on that I had pressed the car key in my pocket against the side of the chair I had sat in and the radio signals from the key activated the unlocking of the door and beacause the pressure was applied for longer than a few seconds the windows also came down...My chair at work was in a room next to the car-park where my Porsche was parked. So I think you must have done something similar and there is nothing to worry about, really...Remember, these remotes work through radio rather than infra-red signals and you can activate the system from indoors...
  16. Dear friends, Not long ago I was happy to report on the aircon failure being fixed cheaply by re-gassing the system. A few weeks later I am getting a whining sound, increasing and decreasing in intensity when revving the engine, it's like a sad orchestra singing a bad tune and it's all nice and quiet when I turn the aircon off...Any ideas, please?
  17. This is terrible news! I would certainly get a qualified second opinion, then I'd try to approach Porsche headquarters because even out of warranty this should never happen at this mileage, but failing this I would try and find a less expensive fix like you yourself suggested...Good luck!
  18. Living in the UK myself and relatively soon needing a tyre replacement on the front wheels, I have obtained a quote for Dunlops 9090 (I am very happy with this model, I've had no probs such as noise or vibrations)and it was just £133 for the front and £200 for the rear per tyre, all inclusive, i.e. valves, balancing and VAT. The wheel alignment can't be much more on top and I would recommend "Central Tyres" where I have had a good service on previous cars, rather than go to Porsche garages...
  19. Thanks for your help!
  20. You are right, the usual lights are not great, but I don't know of a solution. Hopefully now that you've raised the question in this forum I'll benefit as well (2000 C4).
  21. Thanks for the info, any idea how much replacements cost? Prices are detailed in a previous entry on page one...
  22. I've been lucky enough (for now) to escape with just regassing the system...
