jose
Everything posted by jose
  1. An update. Changing coils and spark plugs resolved the issue.
  2. Will replace O2 sensor as last check before taking it to the mechanic.
  3. An update. Summary insert MAF, cleared CEL, started vehicle idle. Codes are reduced to three codes.
  4. MAF was unplugged. Put it back. CEL came back.
  5. I had this actual values. Anything wrong here?
  6. I have durametrics with very limited knowledge. Basically reading the codes. But with specific instructions I can follow and post results.
  7. Yes, I clear the codes after replacing it.
  8. Update. Coil replaced. Same codes. Passenger side axsust seems misfiring. Driver side is okay.
  9. I cannot understand why this hose was there. My last mechanic replaced the waterpump and coolant cap not too many miles ago. I made a purchased same brand "beru". I will attempt to do it my self and reroute the hose. I'll rescan and report results.
  10. Thanks for reply, I cleared the codes and reappeared again. What mean the P1313? Can a Single coil problem cause the simultaneous O2 sensor bilateral? I have an update pictures of cylinder #1 coil. Coolant reservoir hose might be the culprit.
  11. Thanks for reply, I cleared the codes and reappeared again. What mean the P1313? Can a Single coil problem cause the simultaneous O2 sensor bilateral?
  12. Hello, Having rough runing. Durametrics scan this codes. Seems the problem can be cylinder #1 misfire. What can be the possibles issues? Spark plugs? Coil #1? Anything else? Thanks in advance
  13. Which is the recommended oil viscosity for caribbean temperatures? Thanks in advance
  14. Hello, I have a question since wiring is necessary to install this camera. Where is the recommend power extraction is recommended?
  15. I have a pending oil change, will take advance make 2 job at once.
  16. Thanks Loren, The car has around 118,000 miles. Recently changed all struts with some tie rods. Will lift the vehicle and check left side suspension area Regards, Jose
  17. Hi Folks, Recently had an unusual sound while turning the steering wheel. Symptoms: Squeaking sound front left side of wheel when turning steering wheel to right. 1999 C2 996
  18. I sent my cluster to EZELECTRONICS they diagnosed an internal problem on the circuit board. Jose
  19. Did all ready. I sent it for repair
  20. I was using it with LEDS for 8 yrs. No single issue. I just got bored of the blue light then went to original, now doesn't work. I start thinking in a short inside the instrument cluster. 😞
  21. Thanks for share. B10 fuse is Ok. I suspect the instrument cluster board problem. Still no idea. Other instrument cluster lights working fine.
