pbahorich
    Laguna Hills, California, USA
    1999 Carrera 2 Coupe
    1979 911SC Targa
pbahorich's Achievements
  1. Be careful when you connect to the power cord that comes with the V1. The color coding is reversed depending on which end of the wire you use. Read "Making your own Power Cord" section of the V1 owners manual (on page 17 of my version). It says "NOTE: The sequence of wires must be reversed from one end to the other." If you face the plug with the contacts toward you and the cord on the bottom, the one just left of center is ground and the one just right of center is power. These are always green and red, but not necessarily in that order; there's an equal chance it will be red and green.
  2. I have just successfully completed my install of a hardwired V1 radar detector. Don't use the dome light wires, because they have power at the wrong times. What you want to use is the power wire for the sun roof. This way it goes on when the car is running and off when you leave the car. Use the wire colored green and brown with a black stripe for power. Use the brown wire on the dome light assembly for ground. The instructions for the 997 install are misleading. Be careful when you connect to the power cord that comes with the V1. The color coding is reversed depending on which end of the wire you use. Read "Making your own Power Cord" section of the V1 owners manual (on page 17 of my version). It says "NOTE: The sequence of wires must be reversed from one end to the other." If you face the plug with the contacts toward you and the cord on the bottom, the one just left of center is ground and the one just right of center is power. These are always green and red, but not necessarily in that order.
  3. Have you had any luck finding this? I want to do the same thing on my 99 996. I'm guessing the sunroof motor harness might have the right wires, but I want to see a schematic before I start cutting wires.
