jlobo941
    Denver
    Maserati Coupe GT //Straight pipe to Stebro Rear Boxes, EVOMS ECU Tune//
    Porsche Cayenne Turbo //3" catless straight pipe exhaust with resonated Xpipe, EVOMS intake, diverter valves, and ECU tune//
jlobo941's Achievements
  1. Hey guys, I think I messed up. I purchased a 955 Techart lowering module only to realize it is not compatible with 04 models which were built in 03. Unfortunately, mine was built in 9/03. I have done some research, and it has pointed to possibly changing the level sensors to the post 04 versions, but every post I read is very vague. Does anyone have part numbers or expertise on the subject? Thanks!
  2. thanks for the reply, may I ask how much you picked it up for?
  3. I have done a lot of research, but definitive answers are few and far between on the existing threads... I really like the idea of the lowering modules, but I do have a few questions. First, with a lowering module, are you able to achieve the full up position as in stock form? I have read a lot about the Techart module which seems to have a "sleep mode" so when you park, it dumps all of the bags to the bump stops, do any of the other modules do this same thing? Is there a module that will give you any higher than stock heights? (I recall reading somewhere that the techart module will allow for 20mm higher than stock and 50mm lower than stock, does that sound right or even possible? Thanks!
