moeffi_86
    GERMANY
    Carrera 4
moeffi_86's Achievements
  1. Try 2543 Hi Loren, I tried 2543 (several times) as you said, but this code does not seem to be right. Is there another one to try out? Did you use the method in the Lost Radio Code FAQ to find your serial number? I suspect not. Please use that method and post the serial number returned on the display. You were right. I didn`t know about the FAQ. I guess there will be no way for you to find out the code as I have the PCM fitted. I removed the PCM to read the serial number from the radio.
  2. Try 2543 Hi Loren, I tried 2543 (several times) as you said, but this code does not seem to be right. Is there another one to try out?
  3. Hi Loren, the battery of my 2001 Carrera 4 just died. After replacing it the radio asks me for the radio code. Could you please help me out? Type: IDIS Model: BE 2580 Serial nr.: Y5051235 Thank you for your efforts in advance. Cheers!
