Stueysv8s
    Auckland nz
    Ctt 03 and 04. Nissan patrol
  • Future cars
    Newer ctt
    Fpv's, xjs, 1979 gtr, Quattro , rx7's, and favourite 280 Capri.
Stueysv8s's Achievements
  1. This is perfect, try and source these from marine shop. As for secondry air pump fans , you don't need them, replace the fuse, pull fans out, clear the valves and pipe( real tight job). Move on. No codes
  2. I have 2 ctt,s so I can swap bits to test faults. One of them for the last 6 months has been giving the same psm, abs and big red brake proportioning sign, my loom is dry, I've swapped the 433 relay by the battery, batteries fine, has 2 garages plug in obd11 ,they can't access it. Has anyone found anything else to cause this? General things to note, I just done the valley pipes and y pieces at the back of the motor,was still ok then but then the expansion radiator bottle split so replaced that, and had welding done on rear exhaust, . Then this problem showed. I think coincidence, and is something else? Also there's a mobridge on the stereo and a Denison blue tooth in there too, could it be them?
  3. I'm with you on this one. Mines using coolant , It was the t pipes at the rear of motor so changed them for stainless ones (valley pies already done)but now leak is rh side wheel. I'm suspecting expansion tank. I'll follow your post and we maybe able to fix our cars. Something for you to check, I had a 300z tiurbo that white smoked badly that was the turbo. Easy fix
  4. We have a buzz from passenger side,. If you turn down blowers to off it stops, it must be relay, can't find it!
  5. Help, problem back but worse.the micro switch fell apart and now need help to get to it please, anyone?
  6. The problem is opposite adjustment to what you think. Instead of tightening your window catch, loosen it so it goes in further. Fixed mine!
