Kamil Barański
Members-
24 -
Last visited
Classifieds
Everything posted by Kamil Barański
Hi, Thing is that in Poland You either buy it in Porsche or these: http://e-katalog.intercars.com.pl/#/produkty/3216303318210-FE34788-O16695-dmuchawa.html which is Febi:) Or: VEMO or HANS PRIES all filters are new. I think I will have to replace it.
- 4 replies
- airconditioning
- blower
(and 1 more)
Tagged with:
Hi All, I have true pain in the axx with one part of my car and that is:955 572 342 01. It's a a blower in the front (from the AirCon) it makes a lot of bad noise, I guess it will brake soon. My question is: 1) Does this part have an OEM supplier? 2) Has anyone had any problems with this part? How long does it take to replace it?
- 4 replies
- airconditioning
- blower
(and 1 more)
Tagged with:
Hi, We have a heavy snow here in Poland so I wanted to use reduction to get home safely. Unfortunately a massage showed up on the screen which says that "4 wheel drive fault......" Car is in the garage now and I cannot get it back to normal 4 wheel drive - reduction is still on. No chance to get it to second type of reduction. Massage stays on I had 2 trials where I managed to get it back to normal 4 wheel drive as I thought that maybe snow did some damage or water etc. nothing. I am looking at many topics here on the forum and it looks like it may be the servomotor? The transfer case was not used very often. Battery was changed 7 months ago. Any ideas where to start? No chance to connect it to durametric as I am over 100 km from Warsaw Porsche Stealership. Need Your help Guys as I need this car to run smooth again. Oil in the transmission was changed 3 weeks ago.
Hi All, The problem is gone. i replaced gas cap and erased the error. CEL didn't show till now. All ok. for now:) Many thanks for all your support.
- 29 replies
Hi All, Can anyone please answer my question regarding the filling of the tank?
- 29 replies
P0455 is a "large vacuum leak in the evaporative emissions system"; often a bad gas cap, but could also be vacuum lines or valve issues in the EVAP canister system. Does it has to do anything with my problem of refueling? The fuel pistol disengages itself after a liter or two being pumped into the tank....? I also see that when I unlock the gas cap, inside the valve there is this little metal which unlocks itself when i put the pistol inside. Once i take it back it stays in that position and doesn't return to the the "close" position. is that natural? it sounds crazy put when i put my finger into this hole and push it it doesn't come back and stays ...lets say "open" Should I replace it? Many thank for Your help.
- 29 replies
Hi Guys, I have the code, itd P0455. Wouldn't that explain the issue with gad filling?? Where should I start now?
- 29 replies
Any suggestions what can cause the issue with proper tank filling? the same issue on different gas stations? Are those pistols different in US and Poland somehow:)?
- 29 replies
Will know tomorrow morning, unfortunately it won't be porsche diagnosis tool. . .
- 29 replies
Oh and another thing i need help with. When i fill the tank i always have an issue that i cannot fill it having the pistol pressed once and kept presed. it always pops up after 2-3 liters. any help what can cause this situation?
- 29 replies
A brief update; i have replaced crankcase ventilation tubes as they were cracked and connected the wrong way. It seems that the idle RPM are not fluctuating. I went back to those guys who replaced the starter and thought that that was the case, the CEL was erased by them but after ca. 60 km came back. Wife says that when she switched off the engine it was on and when she came back and start the car after 9 hours it was on. To bad that i am about 100 km from Porsche Dealer to check if the crankcase tubes solved the issue - partially at least. Guys any ideas now?
- 29 replies
Hi Deilenberger, Yes the intake gasket was reused. Apparently it was in a good shape...in their opinion. They will be replaced this Thursday along with crankcase PCV valves - 2 of them. As speaking of those PCV valves the is one goes from one bank to the other, it has this little nose on one side. What is it? I speak of this part : 948 107 215 03. When I was looking on it in the internet I saw that some offer this PCV without it. Does it has a special role or something? Is it connected via that nose to something? I can't see it on those PORSCHE drawings. Which part do You mean by saying: or cracked one of the hard plastic air-lines? I am trying to do as much as I can in the garage and replace things which can be done by myself without special tools. Rest I will leave to those Guys how made me worrying about my little P(!)G. Many thanks for all Your help.
- 29 replies
Sure thing wvicary. I thnik that based on the status of the PCV valves i will start from replacing them. They are in a very bad shape. Does anyone have those nice PDF's Porsche has for every code? i mean those guidebook how to proceed with each problem, whee to start and what to do.
- 29 replies
Hi Loren Hello Everybody I spoke to an engineer from porsche this morning when i exchanged the oil and filters. He said that that PVC valves are in terrible condition. He said that i should start from replacing all of them to new ones. let me ask one question: can the airflow be a couse of this problem? I know that it didn't come up as a error code but should i exlude it from equation? I think that there is also something wrong with one of the PVC valves as the longest should consist of two cables and in my case it seems that there is only one - the other one is not connected to anything (based on the drawing I got from Porsche) I speak of this one: http://www.carpartsdiscount.com/auto/parts/2005/porsche/cayenne/pcv_system/engine_crankcase_breather_hose.html?3593=344513 What is its purpose? I am not saying that I found the core of the issue but I will replace all of those hoses. Cna it be the gasket under the intake? When the starter was replaced I was told that its ok and there is no need to have new ones. Juged on time i would be better to have them replaced. Can the mechanical fault in injection valves be connected with the starter replacement? Are those the 8 little blue chips i have on both sides of the black plastic intake? Another question about the exhaust... I assume that the error should be before the lamda sensor (oxygen)? Oh..I remember that Guys from Porsche said that its rather a problem with the air leak as it shows up on both sides of the engine. I No issues on misfiring etc. Please let me know Your opinion on where to begin and with what.
- 29 replies
Hi Guys I have all codes now: P0507 Passive, P2177, P2189, P2179, P2187 all are active... Apparently there is a leak in the intake? Unwelcomed air goes to the intake system?
- 29 replies
- 29 replies
Sorry Guys for some errors in the above post, I am driving a highway and writing, not looking to much how the Iphone corrects some words. Again, many thanks for Your input.
- 29 replies
Hi Many thanks for your replies. I am not excluding all possibilities. I refuled my car with a 98 octane gas, checked the gas cap. Light is still on. I don't feel anything strange when driving, speeding etc. But wojen i stop the rpm floats between 800-1000. I thought that the fuel i got lasy time was bad i guess it wasn't the root of the problem. I will let You know tomorrow about those codes. What sensors are undertaker the intake? Whar are those 8 little blue Tunezja/ chips on both sides? Can the oxygen sensor give errors due to the błąd fuel? Last time i filled the gad tank with a 95 octane.
- 29 replies
Sure thing, I will. I was hoping that the description would guide a little bit to the cause of the problem. I remember it right that my friend told the code description. It was in polish :) so the only thing can do with it is to try translating it. He said that that "pure mixture" and car started adding RPM to about 1.200 and decreasing to a normal level. Can' t wait do give some decent info about the codes.
- 29 replies
Hi All, Just joined Your group and hope to share some experience with the Cayenne S, many thanks in advance for helping me out. Is just bought US version of 2005 Cayenne S and recently had some issues with the car. It first started with the starter which needed replacing. After that just after i got my car back a CEL showed up. At this moment i only know the error description not the code. It says that the car had problems with poor mixture of fuel and air and therefore the RPM goes little bit wild up to 1200 RPM. I keep on wondering if that is someway connected to the job that was done - starter replacement? The RPM floats only when I am on N,D or try to park not pushing the gas pedal. I will surely try to get some codes this Saturday, when having my oil and filter changed. I sincerely doubt that it would be a gas cap as It came up after i picked the car from the repair shop. Any ideas what the cause might be? The light is solid and doesn't blink.
- 29 replies
