ktfaut
    Kona, Hawaii
    2000 Boxster base
    2007 BMW X-3
ktfaut's Achievements
  1. Mine is a 2000 Boxster base. Much the same scenario as befell Pete in '09: Turn on headlights, try to adjust the dimmer for the tach and the speedo, smoke begins to emit from the dash - very creepy. Having read Pete's mechanic's discovery regarding the ashtray light, I can say I have looked under the ashtray, a place I keep some bills and change, and sure enough there is what appears to be a "smashed" light bulb at the bottom. Who would have thought. I shall pull it and try to replace it to prevent further short circuits or "grounding." Will still have to pull the cluster as there must be a burned wire within. Pete mentioned mechanic said "by pass that," presumably implying bypass the shorting bulb. Perhaps pulling and/or replacing is equally as effective. Appreciate the input from Chuck as well regarding fuse A5. That's the first place I'll look. Kurt
