Wausau 911
Everything posted by Wausau 911
  1. Had the bumper off for radiator cleaning and DTR lights install. Put everything back together and was looking at it later and noticed some misalignment on passenger side. Can I make adjustments w/o taking the whole thing apart again?
  2. Loren, as the acknowledged expert on all thing Pcar, can you shed light on why my VIN isn't on the infamous list? Thank you in advance.
  3. My '04 C2's last six digits are 260135 and isn't in the above reference chart. Just wonderIng how I escaped the issue? Did different vendor make my IMS? Curious very curious. Any thoughts?
  4. Thank you Loren, I read the bulletin you supplied and my sound is a rattle not a creaking noise, kinda sounds like a clip or something fell off. Guess I'll live with it as I don't want to mess with the described removal procedure. Appreciated your input though.
  5. '04 C2 - sunroof works fine but there is a rattling noise when going over bumps. Any ideas out there of what the cause old be? Thx for replies.
  6. I have an '04 C2 with factory PSE and I have the oval exhaust tips.
  7. I would like to remove the plastic louvers to paint the faded metal underneath, anyone know the removal process? Replies appreciated.
  8. If you really want to spruce up your interior, try looking at www.cocomats.com. Well made and won't show wear. I don't have any connection other that I have a set.
  9. get underneath the back Rt rear of the car and look up at the muffler. There should be an arm you can see going into the muffler which closes a valve. It is a very expensive retrofit - $3,000 for each OEM muffler and that's w/o the electrical wiring.
  10. bump - anyone know if power to the nozzle only activates with wipers on? Doing this mod soon - thx for assistance.
  11. Loren, thx for your input, so may I assume that I can connect the daytime lights into the washer heater power or will the power be on only when the wipers are on?
  12. Wyovine, don't the heated windshield nozzles heat up only when the rear screen deicer is on?
  13. See the exhaust hack in the mods, sounds sort of like the PSE.
  14. Will do Loren, and as always, thank you
  15. '04 C2, owners manual doesn't address this, fuses all good, up & down work fine. Thx for your interest.
  16. Maybe I am just old, but it seems the left side mirror is always in the "dim" setting of the self dimming anti glare function. Is this possible? And if so is their a fix or rest? Thx for replies.
  17. Your the best Loren -wonderful site!
  18. Loren, thank you for your reply. Do you think a window switch is a double throw?
  19. I had a OEM footlight switch and used it for a spoiler switch following the DIY instructions on this site. Wiring went well all soldered up but my problem is the switch will make the spoiler go up but not down. The normal lower switch works fine. Tried moving wires on the new switch around but still no down movement. I know the footwell switch is much less expensive than the OEM spoiler switch and I am just wondering if the spoiler switch has something extra in it to allow the "down" cycle. Any ideas out there? Replies are as always appreciated. Thx
  20. Got it now Loren thx
  21. Loren I have no green "participate" button on my screen, where do I find it?
  22. Loren, I was just looking into the raffle after seeing you post, but I can't seem to find how to enter to send the $-.??
  23. Thank you Loren that's what I thought just wanted to be sure.
