Ricky1
Members-
72 -
Last visited
Classifieds
Everything posted by Ricky1
Thanks Loren... good to know that there is just one part number for both sides... means I can swap them for testing... currently passenger side low beam not working. Drivers side is good. I am afraid though if I swap the headlight control unit that some wiring fault on the left side may fry the good unit out. Not to rush you, but do you know the answer to the second question regarding PIWIS and the headlight control unit? I am on the west coast too and fortunately its a quiet evening for me... thank you.
Hi Jagman1, Thanks for your description that resolved your problem with door alignment. When you have a moment please post some pics... The front passenger door's bottom trailing edge is about 1/2 an inch further out than the right rear doors leading edge on my 2005 CS. Everything seems to be aligned... as in up/down, left/right. When I push in the bottom of the door, somehow it seems the seals are to bulky now and pushes the door bottom out. One significant note though, I took the door apart to change the bowden cable from the interior door latch to the door lock. Everything seems to line up during reassembly. The door closes fine with the exception of the bottom corner of the door jutting out about 1/2 inch. I am suspecting I did not properly reinstall a seal that goes all the way around the door, on the door. I've checked it twice though and the seal seems to match the "good" drivers side... I am baffled at the moment. Thanks in advance.
I've proceeded with removing the trim panel. Hopefully recording what I have done can help others. But I still need to know whether or not I have to drill out 4 rivets at the top of the inner metal panel that holds everything, eg. regulator and speaker, etc.. (looks like I will have to remove the rivets). Pull off the inner panel. It has six retaining clips, what Porsche calls "fixing clips". The locations are marked on the picture. Knowing the locations would help you pull of the panel with minimal damage. One of the six retaining clip base broke off and can't be used again. Two others sort of cracked but can still be used. The red boxes are rivets. The green box locates the bowden cable where it enters into the other side of the inside metal panel. The six yellow circles are where the retaining clips are. Backside of the inner panel. The 3 yellow circles show the retaining clips that were undamaged when I pulled off the panel. The 2 orange circles are where the retaining clips stayed on the metal panel. The one on left shows the base is a bit damaged but still can be used I think. The 1 red circle shows where a retaining clip base broke off, like can't be reused. The 2 green boxes shows plastic blue alignment pins. They fit into two holes on the metal inside panel... so to pull the trim panel off, one has to pull it out from the bottom first (so the alignment pins are out of their holes), then pull the panel up. Across on the top of the inner panel is a strip that runs practically the whole length of the panel. It hooks into a grove that runs the width of the door. There are 3 clips that help retain the inner panel at the top. The yellow circle shows the marks left on the strip by one of the clips. The clips are small and not very strong... so to pull the inner panel off, like described above, pull the bottom out first then just jiggle and lift upwards. The following picture show one of three small clips in a groove at the top of the door. I don't know if it was necessary, but I lowered the window all the way first before pulling the inner panel off. Disconnect the speaker connector (tweeter I think). Then disconnect the bigger multi connector (controls the window and another speaker and power locks I think). The following pictures shows a lever that needs to be "moved" that helps pull out the connector. I will continue with the next post (due to total picture size upload restrictions).
2005 Cayenne S front passenger bowden cable broke so passenger cannot open door from the inside using the inner door release lever... have to open door from the outside. Part number for bowden cable is 95553102400 I think. Followed "Door Panel Removal" instructions. Inner panel almost all off, just have to remove the top part of the panel thats still "stuck" to the door... have to figure out how to "pop" it off without breaking anything. Stuck my hand behind panel and felt bowden cable is broken. The "door panel removal" instructions were helpful. Is there instructions to replace the bowden cable? The cable runs into the door panel to the other side of the door. Do I have to remove the lock actuator? I have no idea right now. Thanks in advance.
2005 CS: Just got starter replaced. Factory Porsche Service changed me time for "disconnecting the coolant pipes under manifold for access to starter" and also charged me for "vacuum fill cooling system" and charged me for the coolant itself. But maybe they could of done it without removing the coolant pipes, ie. just want to make more money off of me. (For what its worth). Yes, I too am curious Sgearyman replaced the starter without removing the coolant pipes.
Starting problem '08 CTT
Ricky1 replied to vchris's topic in 9PA, 9PA1 (Cayenne, Cayenne S, Cayenne Turbo, Cayenne Turbo S)
2005 Cayenne S: Compelled to post this since I just went through the same problem: Cold, starts properly... warmed up, may take 2 to 5 tries to start. Even when cold, its a slow arduous start. Finally, about two weeks ago, the starter just went "click" and wouldn't start again. Towed into Porsche Service, replaced starter, and all is well. Starts properly now. Before starter finally failed: - replaced battery about 7 months ago... no change. - starter gradually got worst and worst... ie. more and more tries before engine started - when engine cold, started on first or second try but still "slow turning" of engine/fly wheel - maybe one out of 30 starts would result in starter "free wheeling", ie. engine starts but starter makes a loud screeching noise for about a second, starter gear/solenoid not retracting? - other times when car started, 4 wheel drive warning would come on, and on a few occaisions, the radio would not work with an amplifier warning. I am guessing the starter draws so much current that the automatic systems check systems doesn't work properly. (With new starter, problem hasn't arisen yet). I've been told when the starter heats up it would draw more current. Any reading under 300 Amps is normal. Anything over 300 Amps indicates a starter problem. About 3.5 hrs of labor to put in new starter. Hope this helps.- 4 replies
- cayenne starter motor
- 957
(and 2 more)
Tagged with:
Intial problem with new rotors and pads ==> horendous sqealling while trying to stop from slow speeds. Solution: Find a long downhill stretch of road with little or no traffic and bed the pads until you smell "brake". As per clarksongli's recommendation... "really stick it to the pads". Well that seemed to have work with two bedding runs on a lengthy stretch of downhill road. Currently, once in a while there is a "quiet squeal" when stopping from a slow speed, but is like 99.99% less noise than before the harsh bedding. I may bed it again soon to try to get rid of all the noise. Pad or rotor manufactures should add to their bedding instructions that propper bedding should bring about "brake smell".
I have a 2055 CS and want to install a back up camera. Like you said, a bunch of the ones on sale on ebay doesn't exactly fit the license plate light cutout. Can you tell me which one you purchased? Thanks for the info. I am going to take a look at the Alpine W920R. Want to change the PCM also... thanks.
Thanks for the reply Clarksongli. "Btw...I bought a set of wheels with the same tires back in the day." are you referring to the Michelins or were they Kumhos? Anyways, I bought the 20" wheels to replace the 22" TecArt wheels for "a while" before I get another Pirelli Scorpion Zero Asymetrico tire for it, sized 295/30/22. Why another set of wheels? In the year and a half that I've owned the 2005 CS, I have replaced three tires already. Tire 1: Pulled the passenger front tire off to inspect brake pads and rotors... rolled the tire away and heard what sounded like gravel in the tire, lots of gravel. Turns out the previous driver had driven on that tire flat and damaged the inside of the tire and all that "gravel" was rubber pieces rolling around. Tire 2: Drove into a gas station and the drivers side front tire popped at the side wall. Didn't see any pieces of metal or anything lying around. Tire 3: Drove out of McDonalds and just caught the edge of the curb. Sidewall split. Getting tired (no pun intended) of this. The 295/30/22 are so low profile and I believe, load value too low for the CS (load value 103 I believe) that I think this is just going to go on and on. The TecArt wheels look really good but I don't want an SUV that can't behave like a SUV, ie. at least have the ability to go on and off a curb. Anyways, I am going to buy another 295/30/22 because the other three are good. As for the 20" wheel set, I am looking at the Kumho STXs now, relying upon your experience. At Americaswheels.com: KUMHO - ECSTA STX KL12 275/40-20 106W, they are $123.51. Anyways, the 20" wheels with the 275/40/20 has more sidewall and takes the "bite" out of the rough roads since I think the original owner changed the springs and shocks to stiffer ones... too rough for me with the 22" wheels.
Just bought a used set of 20" wheels and tires. Tires are about 50% tread wear but manufacture dates are in 2007 and 2009. 275/40/20 Michelin 4X4 Diamaris. Note: Not actual picture of "my" wheels but same style: So I am concerned that the tires are too old. They are Michelins, so they are suppose to be "good", right? From what I have read from serveral web sites, tires should be changed within 5, 6 years. So even if a set of tires were not in use for serveral years, they still degrade. I want to keep using them but I do not know where they have "been", so I think I better look for new tires, even though they are MICHELINS. From mostly the forum, I am thinking of Kumo STX or the Yokohama Parada Spec-Xs. Clarksongli stated in a previous post: "For my summer/all season tire i run a Kuhmo STX. GREAT MILEAGE, good snow performance, only 120bucks a tire, but NOISY.....they have a fairly wide tread block pattern, making them decent in snow with a capable driver. They are also a decent offroad tire, and provide decent grip." I have a question for Clarksongli: The Kumho website states for the STX: Dry = 9, Wet = 7, Snow = 3. Was your snow experience a "three" with snow or better? Thanks for your reply and of course... opinions and suggestions from eveyone else is appreciated. Thank you.
Does anyone have any experience with the following tire brands? Some are from Indonesia, China, Korea and elsewhere. Achilles Saffiro Lionhart Winrun Mayrun Delinte Accelera Nexen Atturo Capital This partial list is from Americaswheel.com with size being 275/40/20. The least expensive one is the Achilles at $78.03 each. If I am buying, I would like the Yokohama Parada Spec-X at $154.34. So you think the Yokos are really twice as good as the Achilles... $78.03 per tire is so tempting.
The picture above is a brand new rotor prior to any use, which also means no bedding. Here are pictures of the rotor after three beddings ( each maybe a month or two apart) and about 6 months of light everyday city use. Driver side rotor: Passenger side rotor: Obviously there is a problem with what I would call uneven contact/wear. I do not know how to get rid of it, ie. make it wear evenly or is it a defect of the pad or rotor itself. Look forward to replys from the expert Forum members. Thank you. The only thing I can think of is I went too easy when bedding and should really "go at it".
Thanks spooltime. I will give it a try soon. I want to put in a backup camera where one of the license plate lights are. I will purchase a camera on ebay. Don't know which one yet but there is no exact fit one for a 2005 CS (that I know of yet). I don't plan to "hook it up" to the PCM. Probably an extra monitor. Thanks again.
I had to get a cracked bulb and water out of my side indicator. One of the first things I had to do to the 2005 CS, front passenger side. Wheel well without liner. I think I tried not to take the whole liner off to work on the side indicator but I counldn't. The two bolt locations are circled in red. I had to use an extension to get to the top one. My side marker's bulb "holder" (don't know what else to call it) was melted. The bulb was also cracked with piece of glass inside the indicator housing. The last mechanic that worked on it must have been careless and not "seated" the bulb and its bulb socket properly. Also (not pictured) were a couple of electrical harnesses that were not snapped back into their cable retainers so that they were just loose. Careless mechanic probably didn't care since no one would see it anyways. Hope the addition pictures help. Members make this a great Forum!
dphil66 I want to ask you if you used any brake anti squeak compound on the Hawk LTS pads? I am using Powerstop rotors and pads and together with proper bedding, they screech really loud. Use of anti squeak compound and brake lube didn't help. This is the first time the anti squeak compound didn't work for me, ie. on the 2005 Cayenne S.
Powerstop brake kit update: Purchased kit in Nov 2013. Installed in February 2014. Its now September 2014. Current comments: Kit has less bite than original Pagid pads. Easier to modulate brakes in normal city traffic. But it does have less stopping power, ie. I had to press the brakes a bit harder for the same "quick" stops. But, easier modulation eliminates the lurching that happens when the SUV is moving slowly in traffic and you touch the brakes a bit too hard even though you used very little foot pressure. The drilled and slotted disks looks good but I couldn't tell you of any performance advantages due to the fact I don't drive the SUV very hard. Nothing I normally do would bring up fading. BUT... I do have a problem with this kit... horendous squealing/screeching from both front brakes. I've beded properly, serveral times. I've applied anti sqeak compound on the back of the pads (using this stuff has never failed me in any of my previous non Porsche vehicles). I've used brake lube too. It happens at slow speeds when the brakes are applied. Situation: Back out of the garage into a back alley... hit the brakes... "clunk" the pads shift because the wheels were moving backwards. Put it into drive to go forwards. Drive for about three house lengths to the end of the alley to turn left... hit the brakes gently and SCREECH! Super loud, all neighbours would hear it. After hitting the brakes a few times while travelling forward, the screeching would go away. So... pads get out of position when initially going backwards? I've used new retaining springs and reused the old ones just ot see if it happens to both. It does. I am thinking if I double up the spring (which I can't) the problem would go away. I have now given up and am looking at Bosch QuietCast pads. Anyone have a fix without me buying new and different pads? Thanks in advance.
Update: Loosened belt, then checked pulleys, power steering pump and water pump (couldn't reach far enough to check AC compressor and generator). Result: Water pump and power steering pump pulleys: no play and rotates OK (far from a thorough inspection but seems OK). Left and right pulleys: rotates OK, left one has no lateral play, right one has minute play. Tensioner pulley: Rotates TOO freely, eg. spin it with my fingers and it would spin for about 10 seconds before stopping, this to me means there is no lube inside where the bearings are to allow it to "free wheel" for such a long time. Of course, since I don't know what a new one is like, I am just speculating. There is about a 1/2 a millimeter of lateral play... a little more that what "feels" right. My conclusion: A bearing in good condition should have enough lubricant in it so that a pulley won't be able to spin so freely. This means the tensioner pulley needs to be replaced. ECS Tuning has it for about $37.xx plus shipping. I will report back when I install it and hopefully, this was the cause of the noise. As for the engine starting screech... another post: "2004 S starter noise" has good info. 12" adjustable wrench to loosen the tensioner, just long enough for leverage. Home Depot 30mm box wrench was about $12, longer for leverage.
