BillTheButcher
Everything posted by BillTheButcher
  1. It's the fuel sender in the tank. It's over £300 to fix which seems a lot for what is a minor inconvenience so I'm going to leave it as it is for now.
  2. Thanks for all the replies. :) AFAIK the previous owner didn't change the face plate so it looks like something has failed rather than just not being put back right. I removed (and sent away for repair) the instrument cluster in my old B5 RS4. The pixels were dying so a group buy was organised. The results were excellent.
  3. ^ From what you've said there it does sound like the spring might have gone. I'll have a look at how easy the cluster is to remove. Unless it's completely straightforward I won't be competent enough to do it. It's due for an MOT in April so I'll get it fixed then if not before.
  4. Yes, the needle still stays pointing up when the engine's off. This has been suggested as a possible fix but I'm not brave enough to try it: http://www.pelicanparts.com/techarticles/911_fuel_tank_sender_replace/911_fuel_tank_sender_replace.htm
  5. Good question. I haven't looked after the car's been switched off. I'll check tonight. :)
  6. Hello. :) I picked up a 996.1 911 Carrera Cabriolet last weekend. Great car but there is one small fault that I would like to try to fix... The fuel gauge needle is stuck pointing straight up, i.e. way past 4/4 on the gauge. The previous owner mentioned that this might be something simple that I could fix myself. Can anyone tell me what might be causing this fault? (Apologies if this is a repost. I searched but couldn't find anything.) Thanks. :thankyou:
