Bgryga
Everything posted by Bgryga
  1. Hi jayUSA123 I live in southern Massachusetts and have an PST2 unit. Do you still need help ? If anyone else need help I have a PST2 unit v24.(Southern Massachusetts.)
  2. 2003 Porsche 996tt I want to remove my DME from the car because I think the car has a tuned program on it,so I like to buy a NEW Porsche DME unit and install it. I don't want to copy the Old DME program from it. I have my IPASS CODE in hand and a PST2 Unit. Question is do I use my OLD IPASS CODES when programing the New DME Unit . or does the Dealer get me new IPASS CODES for the New DME unit to program it ? I will guess and say use the OLD IPASS CODES to program it I think they stay with the car. I Have three codes: 1-Learn Code 2-DME Program Code 3-Immobiliser Code
  3. So my car with 4 O2 sensors should be set on ODBII ? Not RoW.
  4. Loren: On page two it says 3. The data record can be changed, e.g. from RoW to OBDII ? Is this talking about the seven rows of data that the car uses to run correctly and that tuners use to change timing ,boost, ect, ect
  5. Thank you !! VERY MUCH..!!
  6. What are the steps to reprogram a New/Used DME using a PST2 ? Never did it before.
  7. Yes.. So I have my Ipass Codes from the dealer so I transfer the Dme programing code and the immobilizer code to the new unit. What about the mileage for the car? If I buy a used DME same thing ? One with tune, second to pass inspection .
  8. Do you get the I-Pass Codes from a Porsche Dealer when you buy a new DME/ECU p# 996-618-606-01 so you can program that unit or do they program it with your vin number and mileage when you go and pick it up at the dealer ? Want to have a second DME so I can put a tune on my car ,don't want to mess with the DME that in the car now. That's why I want a second DME.
  9. Thank you for all the input and I didn't know that the stock maps are all stored on the PST2. Which I have one on hand also all I-pas codes from my Porsche. Question: Is there any way to save the Promoitve map that is on the DME now ? So I can go back and forward from stock to performance tunes.
  10. I like the flash from Protomotive. Can I buy a unsed DME and flash that unit to stock so I can get passed Mass Inspection time ? I think I need DME code (PST2) from Porsche for that used unit correct or does the tuner bypass it somehow ?
  11. Porsche 2003 996 TT Does any one have the factory DME Programing Engine mapping software that comes with a factory DME/ECU.I would like to upload if to my DME. Right now I have Protomotive software on the DME (from another owner) and I think they shut down some services like. Is there anyway to see if Protomotive has stop any service on the DME from the PST2 unit ? 1-Secondary air injection=Not ready 2-O2 sensor=Not ready 3-Cat Sensor=Not ready Or should I get go to another tuner to change the program that I have now I am trying to get a mass inspection sticker . Loran: How do I upload from a PST2 unit that I have.?
  12. Any member in Massachusetts/RI out there ??
  13. Thank you one and all for your in-put !!! Thank you again .........Loren
  14. I am in the process of asking a dealer to get me all the IPASC code for my car. Wish me luck !!!. Service manager has sent all my info to his Porsche Rep.
  15. Aw-some ...That's what I am seeing on the Web.Do you know what numbers to use ?.I have a PST2 unit that I bought
  16. I seen this card on a Germany site and the LNR number is circled but it is in Germany and I was searching Anlerncade/Learning code for the key fobs thru a PST2 unit.
  17. I found this in my Porsche books that came with my car. Can anyone tell me what the heck it is used for..??
  18. Thank you.......Loren !!
  19. Does any one know how many IPass codes there are for a 2003 Porsche 996 tt ? Trying to get them from a dealer.
