paul29
About paul29
    Northeast
    2013 911 Turbo, 2015 Cayenne S E hybrid, 2015 Lexus GS450H
984 profile views
paul29's Achievements
  1. Don: Thank you, I have a X431 R and a Durametric , looks like I may need another electronic gadget. I would like to see the service level on my Cayenne;s transfer case lube prior to changing it.
  2. Deilenburger : What model of icarscan do you use and which software version.?
  3. Looking for wiring diagram for pse and location of the valve and electrical connectors.
  4. Anyone have the engine wiring diagram for a 2012 997.2 turbo.
  5. Would like to remove the speedo cluster on a 2013 997.2tt. Any one have instructions.
  6. Is there a provision to vary the volume on this feature and if so where on a 2013 911 Turbo? Thanks
  7. "Clutch cooling volume flow must be switched off" may I assume this means a fluid coolant circulating pump/circuit is temporarily disabled, now is there an electrical connection to this pump or solenoid valve that can be opened/energised to achieve the same condition as using the PIWIS?
