atm
Everything posted by atm
  1. OK so today I went along to the local Porsche breakers and had a look at a 987 airbox. It looked very big. I'm not even sure how you would start removing it via the service hatch without removing the engine / intake manifold etc. The snorkel did look a lot larger. It’s not round but more oval shaped. So it’s probably as wide as the 986 snorkel at it thinnest point and then twice as wide at its thickest. The guy at the parts place said he doesn’t think it would fit as the MAF from the 986 would not fit. So I guess the question is how is the standard 986 airbox removed and has anyone removed a 987 airbox?
  2. OK I'll try that and let you know. Some insurance companies do specify tracking devices to be fitted. I take my business elsewhere. A lot of people in UK now prefer to not have a tracker if it means your stolen car is not returned once the thieves have finished abusing it / being chased by Police. As we say in the UK - its swings and roundabouts.
  3. I thought it might be a tracker or mobile phone type antenna too. As far as I know the car does not have a tracker and it definitely has no mobile phone car kit installed either. I also think the roof seems to go up one side first. The RHD seems to go up and drag the LHD side with it. If I stop the roof half way open/closed the RHD looks higher to the eye and it is stiff to move by hand where as the LHD can move up an inch or so easily by hand. Is this normal?
  4. Hello So I finally got my roof into the service position. I had a bit of trouble with the glass window. It stays the rear side of the roll bar so I couldn't get the top all the way up. I found a handy strap inside the roof which I used to attach to the front bracket. Photos below. So did I do this right? So while we had a look around we found this device which had a sticker on it is saying made in Taiwan. The second photo shows roughly where we found it. The cable coming from it when through the bulkhead into the boot area near to the engine management. I pulled and the wire came off. It had what looked like an aerial type coaxial cable connector on the end. Photos below. So obviously this is now removed. Any ideas what this is? I found one of the cables with the ball jointed ends which holds the back of the roof to the car broken on the right hand side. Photo below. I guess this needs replacing. What I am not happy about is the location of the roof when closed. It seems that the clam shell sits low at the front. It does not meet the two small 2 inch sized 'things' near the doors very well. Hopefully this can be seen in these photos. I also found a ball joint loose inside the roof area. One of the balls with a threaded shaft. It was just loose and rolling around, well it would have rolled around but it was jammed in the foam liner. Any ideas or advice is welcome.
  5. Right ok. So in theory then are we saying that the air box from the 987 version with relevant filter inside will fit 'straight onto' the 986?
  6. I've just fiund the Schnell Manifolds / Headers at 9xauto.com for $999.95.
  7. 6 bhp is not an amazing amount I agree however for me it is part of a broader question of how the 987 3.2 has 280 bhp with the same engine. I believe the 987 has 'an improved intake and exhaust system' to achieve this.
  8. OK interesting I'm having difficulty visualising. I guess drawings would be better. I'll try and find some. If anyone can suggest any that would be great.
  9. I dont have any costings for increasing the capacity of an existing motor. I have just been reading another thread where Todd [tholyoak] installed a 3.6 into an early box which started life as a 2.5 and then became a 3.4 and then 3.6. He seemed to get it going ok although it is simpler if you have a later E-gas Boxster. Its here: http://www.renntech.org/forums/index.php?showtopic=11411 Autofarm are the guys in the UK who seem to know what they're doing when it comes to rebuilding the M96 engines and converting / upgrading. Apparently you can get to 4 litres if you start with a 3.6 and they oversize its bores.
  10. How much are they?
  11. Hmmm OK thanks
  12. Hello Just wandered if anyone has changed their seats and if so what are you using? Thanks...
  13. Yes - unless you pay extra for the carbon / sore elbow upgrade.
  14. Hello While reading through lots of posts I read something about the 550 986 having the 987 intake. If there much difference between these - normal 986 S / 550 version? Is this why the 550 has 266 bhp compared to 'just' 260 on the normal 986 S? Thanks....
  15. bump on this question, i dont see why it cant be done i'v had a couple of 1600cc vw motors built to 2332cc's and they have been very dependable and very strong motors This doesn't necessarily answer your question: I think there are other differences other than 'just' the bore and stroke between the various 2.5 / 2.7 / 3.2 / 3.4 / 3.6 / 3.8 units.
  16. Plenty of owner drivers out here who dont want or have money to throw away man. Not sure many would admit to that though! Chill yer boots. Which auto module do you have? I'm thinking of getting one, which is best/easiest/cheapest?
  17. I've been thinking about this. The 3.2 987 comes with 280bhp and has exactly the same engine as the 986. So from what I read about the 987 it has a revised intake system. Also when I heard my friends it definitely sounded a lot raspier which made me think it might have a different exhaust system also. I'm sure I saw a picture somewhere of the underside of the 987 and it had much more purposeful tubular manifolds.
  18. Hello I'm 6' 1" with what I would say relatively long legs. If it helps I buy 33" waist jeans [if I can find them] and 34" leg. I find the seat in my 986 is not good. I have the standard seats with standard adjustment ie electric for the back only. The problem for me is that my left knee gets in the way of my left hand. As I am in the UK it is a RHD. So when I have my left foot over the clutch pedal and my left leg hard against the lower centre console my left knee is almost touching the steering wheel. I have considered different seats but done nothing yet. My plan now is to remove the seat/s to see if I can adjust them somehow. I think if I can remove some of the sound proofing foam behind the seats and adjust the runner in some way to sit further back then this may give me an inch or so which would help. I am also going to remove the lower centre console since this may give my leg some extra space. I used to get pains in my back until I realised this was due to me having the seat too low. Now I have it one notch up and all the way back obviously and tilted as far back as poss till it hits the carpet/foam behind. I have tried a 987 with the standard seats and it didn't fel any different to me. I believe they have moved the pedals deeper on the 987/Cayman but for me the biggest improvement was the ability to move the wheel up. The seat backs are definitely higher too on the 987. I wander if these can be retro fitted to the 986. I thought about getting the Recaro racing seats too but I am not sure how they would be for longer drives as they have very little padding. Its going to be expensive at £3000 to try them. Has anyone used any other seats in ther 986? I know where there are a pair of Sparco Milano seats going begging but I have checked and Sparco do not list/make a runner for the 986/996 so if I wanted to use these I would need to get some brackets made up.
  19. Hello I'm in the UK and I see 997 sales troublesome for the 2 and the 4. A friend who is in the trade [sort of] called me Wednesday to ofer me a 997 C2S 2005 with 6000 miles on the clock for £57,500. The car had some specification and therefore would have been £70,000 - £75,000 new. It was by no means a lemon. There may be a problem with the 4 over the 2 as the 'turbo look' has gone. I still like the 996 C4S and thats probably because of this. Where as the new 997 C4S looks almost identical to the 2 so for the average shopper why pay the extra 4 of 5 thousand pound? Especially when the 2 is so good! If someone is buying for image then the 4 badge is not very noticeable.
  20. I'd guess it is something to do with the seat position. I have a coupe and have tried sitting in the back. I also tried sitting in the back of a cab and it seemed a lot further forward. I'm not sure if this is just the shoulder area or the whole of the back seat area.
  21. I have the standard shifter in my 997 C2S. When cold 2nd is very stiff. So much so that I often avoid it. I also find going into 1st from 2nd very stiff. With my 986 it is a lot easier and I do this regularly. You dont want to get caught 'off cam' in a 986. At least the 997 has grunt and 'off cam - or variocam' is less of a problem.
  22. Don I have a 2004 C2S which i bought second hand. I dont have the spacers so cant comment. I didn't even know they were available but now I do I am curious... I have the Sports seats. I have tried the standard seats and the adaptive and I orefer the sports. The standard and adaptive seats have a lot more padding. If you want more cushion then go for either of these. The sports seats have less cushion and as a result are harder but I think this gives much better feel. Thats why Ii prefer them. I have the standard shifter and I find this troublesome getting into 2nd. This is more of a problem with the sport shifter. It can be retro fitted so dont worry too much about it. Some people say the standard plastic mount is not very sound and can break - leaving you holding your gear lever. Retro fit billet mount is much more solid either ith or without a shorter throw. I have heated seats too - nice when its freezing! I have the smooth multi function wheel. The buttons are useful but I could live wihtout them. I do prefer the smooth feel of the wheel so I would recommend thinking about a different wheel. I have the dimming mirrors and recommend these. Rain sensor I could live without. Colured crests - gotta have these but can be retro fitted. Sport Chrono I have - this seems like a must have but the jury is out on the benefits. Bose I dont have but wish I did. Then there is PCCB on my wish list - its all about the carbon!
