Bill Cage
    Alabama
    2004 Porsche Boxster S (Manual Transmission)
672 profile views
Bill Cage's Achievements
  1. Thanks Loren. My guess is that MOST programming is something only available with dealer specific tools (PIWIS, etc) or is that something that can be accessed by a shade tree mechanic Calling myself a mechanic, shade tree or not is being generous!; mechanical tinkerer is probably more accurate, but I do enjoy working through issues like these. Thanks again for everyone's help.
  2. Ok. The only reason that I am aware that the codes are there, is that I purchased a OBDII device to shut off an airbag alert from when I repaired my window lifter and took out the airbag without knowing the consequences. After I cleared the code for that, I checked on everything else. I assume that the alarm code saying the radio was not found can safely be ignored. The instrument cluster seemed superfluous too since the instrument cluster has shown no problems (the radio was swapped out years ago). The two that I wonder about are the PCM control unit and the automatic air con. I don't know why they would be on the MOST bus so I don't know why removing the stock radio would be an issue. Can anyone state whether these codes can safely be ignored? ...and I guess, it would be interesting to know why they would be connected to the radio circuitry. The car does not seem to affected by these codes, so I my thinking is ignore all of these, but the anal side of me wants everything cleared. Thanks for the insight!
  3. This is a very old thread, but then again, I have an old car! Exact same problem as Awesomebang described all the way down to the brand of the after market radio! I am convinced that the codes being displayed are related to the swap out of the radio, but the question is how to resolve this. JFP in PA says the MOST bus needs to be reset to reflect the change... how is that accomplished?
  4. Thanks! This is the diagram I have been looking for. Do you happen to know the speaker impedances for each speaker?My new amp is a five way. My current thoughts are to drive the dash speakers with two; the door speakers with two; and the sub with the sub out. The question then is what to do with the rear speakers. It looks like they are driven in a mono configuration stock,so my thoughts are to drive them with the doors. Has anyone done similar? I assume that I could get into the box and separate the speakers and run another speaker wire to be able to drive these independent of each other. I could then wire them in concert with the doors.Any thoughts out there on this approach? Anyone else gone through this and have other suggestions?
  5. The car is a 2004, Boxster S - 986, with "Bose High End Sound Package" option. This Bose system has the CDR23 head unit and an amp in the front trunk. There are left and right speakers in the dash, the doors and in the rear mounted speaker box. The rear mounted speaker box has two small speakers on the left and right and a large port in the center. I am a persistent person, but I am finally having to reach out for help. After several months of off and on searching for information, I finally decided to pull the trigger and replace the head unit in the Boxster. From reading an unbelievable number of posts on this and other forums, I was convinced that the best course of action was to circumvent the MOST system and replace the head unit and amp together. Contrary to most advice, I plan to keep the original speakers (at least initially). Wiring is the challenge. My thoughts were that I would replace the pre-amp wiring with new since that is where the MOST system is in play so this was a no brainer. I purchased a wiring harness from Crutchfield to keep the original harness intact. While it did allow me to keep the harness, it only mated to 3 wires (and Crutchfield had two of those wired incorrectly). Luckily searching this forum and using my multimeter, I was able to figure out what was needed for the head unit. Pulling the pre-amp wiring from the new head to the front trunk turned out to be easier than I was expecting and wiring the amp for power is a breeze since it is almost on top of the battery. Now, speakers. I thought this was overly complicated from the post and some extensive DIY posts that I read, but I pushed on. I hunted for days on end to find a wiring diagram that matched what I was finding in person and have still not found it; I have looked at numerous ones, but none are actually like mine. I have come to appreciate that Porsche has many ways to wire these things and it is almost like everyone is unique. Not having a wiring diagram that worked, it was pretty easy to separate the speaker wires from the others on the wiring harness that connected to the original amplifier. My plan was simple, put an audio source on each of these and map where sound comes out. The first unusual thing that I encountered was that there were only 5 speaker wiring pairs. I expected 6. As it turned out, two pair mated to the left / right dash speakers; two pair mated to the door subs; and the last pair drove both speakers behind the seats. This is odd and made me wonder if there is actually a subwoofer back there, especially with the large center mounted port and the fact that the visible speakers are very small. Has anyone else dealt with this configuration? Does anyone have a wiring diagram that matches this? The amp is marked as a Bose 996.645.333.05. I have searched for information without any luck. The pins are such that it appears to be a 5 way amp, but I would typically think that the single would drive a sub, but all the information that I have seen says that the door speakers are actually subs. My thoughts right now are to continue to treat the door speakers as subs. I am going to wire them in serial to get the impedance up. My understanding is that they are 2 ohms individually. I will drive the two dash speakers normally and then drive the rear speakers as a mono channel. Any experience and/or advice out there? Thanks
