mharrell
    Denver, CO
    POC (Porsche Owners Club)
    2004 Porsche Cayenne
mharrell's Achievements
  1. If anyone is looking for this in the future, here are the torque specs (including specs if you are changing Valve Body): Hydraulic Pressure Sensor 1 or 2 to Valve Body: 5 Nm Multifunction Transmission Range Switch to Transmission Bolt: 6 Nm Oil Filter to Valve Body Bolt: 10 Nm Oil Pan to Cylinder Block Bolt (tighten in diagonal sequence and in stages): 8 Nm Oil Pan Drain Plug: 20 Nm Transmission Fluid Temperature Sensor to Valve Body Bolt: 10 Nm Transmission Output Speed Sensor to Transmission Bolt: 10 Nm Valve Body to Transmission Bolt (these are stretch bolts and need to be replaced every time, only ~$15 at dealer): 8 Nm + 90 degrees
