cagradic
    columbus ga
    914,928,Cayenne.
cagradic's Achievements
  1. I Have 12+ on both relays # 30.Get a ground on 87 through the pumps. Can jump across relay and pumps run! Any Help Out There!! Some else had This Problem?
  2. Fuse under the hood closest To The Engine! Under the hood! Still Looking For The Fuse Number!Fixed it All the codes!!Must Have One For The Left And Right!! Car Repaired!!
  3. Had Only Had To Replace One Coil Up to To This Point With no Problems!!Untill #3 kinda Exploded!Maybe I Should Have Replaced Them All! I Told them 2!! # 1! Brim Coils
  4. Yes I Did Twice! The Same result!! Did It Kill The ECM??? Or Is The Wiring. Did The Water Pipes 200 Miles ago Starter Too!Everthing feel right into place!!!
  5. 04 cayenne s all the sudden starts running poorly check engine light comes on! Generic code reader says p0264,p0261,p0267,p0270,p0351,p0353,p0354,p0354. And Missing on 1 3 4! Put new coils on right hand bank!! Coil # 3 was hard the get out of the head!!! And Looks like It Kinda exploded inside???? Same Codes before and after coil replacement!! Any Ideas?????? 100,000 miles
